Drives: none
Upgrading 2013 suspension to 2017. Parts needed?
After reading some reviews of the new suspension changes for the 2017 model year it sounded like a worthwhile upgrade if I could find the parts cheap enough. I managed to find a complete set of stock 2017 front and rear strut assemblies. That leaves me to just buy the stiffer rear sway bar and matching bushings. Can someone confirm that these are the correct parts?
20451FG002 (sway bar) 20464CA020 (bushing) I don't believe any other significant parts have changed, correct? BTW, it seems the stiffer sway bar is also shared with the 2008 WRX so it might be possible to find one second hand. But the bar only costs ~$110 and the bushings are $8 each so there's not a big reason to buy used. Thanks! -Matt |
Drives: Crystal White Pearl BRZ Limited
I was looking to do the same - did the part numbers that you listed end up being the correct ones?
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
You can check out LEEPARTS on EBAY. They may have relatively new used salvaged parts that you may need (I got my 2019 TRD SE exhaust & ABS sensor from them).
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
#4 | |
https://www.ft86club.com/forums/showthread.php?t=142230 Post #3 - Andrew |
Part numbers are listed in the bottom comments
![]() Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
| FS: 2013 FRS Chassis, suspension, body parts | Hilux | Brakes, Suspension, Chassis | 24 | 02-22-2017 08:19 PM |
| Stock 2017 FR-S / BRZ Needed for R&D | FRSport.com | Southern California | 2 | 09-21-2016 12:56 AM |
| looking into upgrading suspension | Mattygt86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 10-09-2015 11:46 AM |
| 2013 86 parts needed in China | FrankAbel | ASIA | 1 | 05-15-2014 09:44 PM |
