Drives: 2013 FRS, 1995 Celica GT4
FS: 2013 FRS Chassis, suspension, body parts
Putting these two into one thread. 2013 Subaru BRZ (Sport-tech) 26,700 km, and parts, and parts from a 2013 Scion FR-S, 25,005 km.
If parts are not either listed below, or pictured, they are sold. Engine/Drivetrain: -Two transmissions 6mt $800 each - one has 26,000 km, the other 25,000. -Rear differential $350 -Axles LH and RH $100 each -Driveshaft $100 -Two OEM headers with catalytic converters $200 each -OEM complete catback exhaust $250 Interior: -Proximity (smart key) key and push button start system, complete with ECU, door handles, ignition, all sensors and all wiring $400 -Base FR-S seats, not heated. Will fit many cars, has flat rails. $500 pair. Very clean. -Steering wheels $100 each -Steering wheel airbag FRS $450 -Door cards/interior panels $20-80 each -Manual climate control panel $60 -Manual Climate control HVAC unit $120 Electrical: -Body ECU, miscellaneous sensors, control units $20-60 -Tail lights $40 each side Suspension / Brakes: -Brake calipers $40 each -Brake rotors front or rear with low mileage matching pads $80 per axle -LH control arm, front, rear, upper, lower, toe arms, etc $40-70 each -Hubs/knuckles with or without wheel bearings $80 each -Steering rack with tie rod ends $150 Body/Chassis: -Rear subframe $120 -5 Axis genuine body kit $750 (rear spats, side skirts, and front bumper - front bumper has some damage, but is fixable. Other parts ok) Located in Winnipeg, MB. Will ship anywhere. ![]() Located in Winnipeg, will ship anywhere. ![]() ![]() ![]() ![]()
Not Bаnned Anymore
Drives: Heavily Modified FRS
Site Moderator
Drives: ichi 86 Project
Please follow the member classified rules (#2) or I'll delete the thread
thanks ichi |
I'll get on that.
Drives: brz
Drives: brz
found out the piece i was talking about is called 'b-pillar cover' if that helps. that picture i tried posting doesnt show up for some reason. lmk
Oh, didn't notice your post. Yes I have the B-pillar cover. PM me to proceed.
PMed for some items!
Drives: GT86
PMed
#10 |
Still have a lot of these parts!
#11 |
Drives: 2013 GBS BRZ
PM'd
#12 |
Drives: BRZ. R34 GT-T
I'll take both of these pieces if you still have them.
https://www.google.com/search?q=frs+...CDn1h3fg5gM%3A THey are the two pieces on the left.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
#13 |
Drives: Toyota 86
Pm'd
#14 |
Brap Brap
Drives: 1986 FC3S RX-7, 2013 FR-S
Rear subframe shipped to 29063?
| Black Friday Specias @ RallySport Direct.com (Brakes, Suspension and Chassis Parts!) | RallySport Direct | Brakes, Suspension, Chassis | 6 | 11-30-2014 12:49 PM |
| Suspension and Chassis Items IN STOCK and READY TO GO!! | RallySport Direct | Brakes, Suspension, Chassis | 1 | 09-17-2012 11:34 PM |
| Wheels tires suspension chassis brakes | Calum | Site Announcements / Questions / Issues | 1 | 07-15-2012 11:14 AM |
