Old 07-16-2017, 02:22 PM   #1
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
Some foglight issues!
I recently bought a set of winjet fog lights, I wired them up in accordance with a number of tutorials here.
Right now the light on the fog light button will turn on inside the car but when I push the button the lights do not come on.
I figured that since the wires are all connected (one big circuit?) Wouldn't the light coming on inside mean the wiring is correct?
Does this mean I have bad bulbs? Or could something else be the culprit?
Any suggestions on how to diagnose would be appreciated.
02.ACCORD.DUDE is offline   Reply With Quote
Old 07-20-2017, 04:45 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Pics of the wiring might help out
Old 08-01-2017, 10:30 PM   #3
BushidoSpirit
BushidoSpirit's Avatar
Drives: 2016 Halo FR-S, 1982 VW Rabbit
Not sure if you've solved it by now but, I just installed this kit on my car and had no issue other than the ground wire to the actual harness in the engine bay being really short.
IIRC, the switch itself has it's own power loop and the yellow wire (signal I suppose) is used to turn on the actual fogs. If you've checked the bulbs and you know for sure it's okay, check that yellow wire going from the fog light switch into the engine bay. Could be that, could also be a bad ground in the harness. I don't have pics but I just found an existing ground (on the front driver side frame below airbox) and just wired the harness to that.
Hope that helps.
BushidoSpirit is offline   Reply With Quote
Subaru DRL LED vs DRL LED with Foglight ZRB Cosmetic Modification (Interior/Exterior/Lighting) 0 11-13-2016 09:16 PM
FRS Foglight Switch? 636 Cosmetic Modification (Interior/Exterior/Lighting) 19 03-10-2015 04:47 AM
H11 LED Foglight FRSure Cosmetic Modification (Interior/Exterior/Lighting) 10 03-07-2014 11:37 AM
Foglight tints? manonastick Cosmetic Modification (Interior/Exterior/Lighting) 11 01-23-2014 04:23 PM
Foglight Cost FRSure Cosmetic Modification (Interior/Exterior/Lighting) 10 12-04-2013 04:57 PM
