Old 07-12-2017, 05:54 PM   #1
chazmuska
chazmuska's Avatar
Drives: 2014 Scion FR-S
16 or 32 bit ECU? Should I lean the air if....
Do we have a 16 Bit ECU or 32 Bit ECU? The reason I ask is because the IAM (Ignition Advance Multiplier) has a range of 0-1 for 32bit ECU's vs 0-16 range for a 16bit ECU. Just wanted to know what to expect when datalogging.
Also, since my car is bone stock running a Stage 2 EL map on E85 fuel...can I be "expecting" to decrease my g/sec values when trying to do a MAF Scaling. My logic of thinking is since I'm pumping less air, compared to a car with intake/ exhaust performance parts, the values from Shivs map would be higher since the Stage 2 map had aftermarket parts which are essentially moving a lot more air than stock setup right....so the g/s (grams/sec) values should be less right?
chazmuska is offline   Reply With Quote
Old 07-12-2017, 06:38 PM   #2
steve99
32 bit ecu
Maf scaling is calibrating the maf flow, this o nly cganges if you change maf housing , ie change intaje
See coloured links below
Old 07-12-2017, 06:48 PM   #3
chazmuska
chazmuska's Avatar
32 bit ecu
Awesome, thanks for that clarification!
Running lean at high RPM BigBrainedMonkey Engine, Exhaust, Transmission 5 08-30-2022 04:45 PM
Running lean ? Maybe ? lizbrayan Engine, Exhaust, Transmission 35 06-19-2016 12:16 AM
Syste!m too lean bank 1 jonbonazza Issues | Warranty | Recalls / TSB 55 07-05-2014 01:36 AM
lean at idle only woode Forced Induction 5 05-03-2014 04:48 PM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 12:53 PM
