Northwest AK, ID, OR, WA
Old 07-11-2017, 03:24 PM   #1
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
50K Maintenance.
Welp. Time its almost time to do another old change, and i'll be creeping up to that 50K. I usually do oil changes every 3k-3.5 depending on what my schedule is like. Any major services I should be doing around that mile stone? Maintenance schedule I found online was all over the place.
Chen is offline   Reply With Quote
Old 07-11-2017, 03:48 PM   #2
burningjello
burningjello's Avatar
Drives: 2016 FR-S
I think 50k is pretty normal. 60k is when you start worrying about Spark plugs, ATF, and brake fluid.
burningjello is offline   Reply With Quote
Old 07-11-2017, 08:17 PM   #3
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
you have a new motor, so you're still a long way off from plugs. As for other stuff, you've already done driveline fluids, so maybe brake fluid?
Decay107 is offline   Reply With Quote
Old 07-12-2017, 11:13 AM   #4
Chen
Regional Moderator
Chen's Avatar
Break fluids it is. Drain it all or just top it off?
Old 07-13-2017, 02:13 AM   #5
Imrac
Drives: 13 SWP BRZ Prem
http://www.cars101.com/subaru/maintenance-2013.html
Basically:
Oil Change - every 7.5k Miles (Or less depending on driving habits)
Engine Air Filter - every 7.5k-30k miles (YMMV on this one depending on air quality, excessive idling, short trips, urban driving)
Spark Plugs - Every 60k miles
Brake Fluid - Every 30K miles(Probably Clutch fluid too if applicable) (Fush, you do not drain the fluid. You don't want the system to go dry, it will cause seals to fail and corrosion to occur))
Tranny/Diff Gear Oil - Every 30k miles (Longer if you treat it nicely)
Pad/Rotors - Inspect every time you have the wheels off (Can vary wildly depending on driving habits)
accessory belt - Replace as needed (When tearing/chirping/squealing occurs)
Coolant - 130k miles, then every 75k (YMMV, look at the fluid and radiator cap occasionally for discoloration and residue.)
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
The Following User Says Thank You to Imrac For This Useful Post:
slizoth (08-15-2017)
30k Maintenance VABeachBRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 08-07-2017 01:43 AM
First Car & First Maintenance. JARE_ee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 04-14-2016 11:23 PM
50k maintenance RickyRacer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-27-2015 01:21 AM
For those who do their own maintenance FR-S89 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-24-2014 12:03 PM
25,000 Where can I go for maintenance. laley81 Southern California 9 09-20-2013 05:00 AM
