Old 07-22-2015, 11:10 AM   #1
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
50k maintenance
Hey guys,
New owner of a used FRS here. Was wondering what ya'll would recommend for a 50k service interval?
The only thing done on the car has been oil/filter changes every 7k km or so. As well as a engine air filter and cabin air filter replacement
I'm planning on doing tranny fluid, diff fluid, and maybe breaks.. but i'm not sure if I should go to the dealership to get this done or a good shop in the GTA.
What are your thoughts?
RickyRacer is offline   Reply With Quote
Old 07-22-2015, 11:39 AM   #2
CBR600RR
Drives: Raven Black
The manual will tell you what should be services at that km
Old 07-22-2015, 11:55 AM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
if you have any kind of experience doing oil changes, doing a transmission and diff fluid change is no Different IMO
do some researching, there are some nice DIY articles on here about doing it. save yourself the money of having someone else do it, but that's just me
going forward, look in your service manual, i think the only thing they recommend at 50K KM (30K miles) is for the brake fluid to be changed, dont think that is something that HAS to be done
change out your In Cabin Filter, the Dealers never changed mine out when i went for my service, mine was FILTHY!!
Old 07-22-2015, 12:22 PM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Suggestions would be...
Brake Fluid Flush
Alignment Check - Perform alignment if out of spec
Tire Balance - if not done
Tire Rotation - if not done
Trans and Diff can probably last another 10k - Change at 60k
Things to check would be....
Brake Pads and Rotor
Struts for leaks
Belts for cracking
Coolant isn't due for a long time so I wouldn't touch that.
N1rve
Old 07-22-2015, 02:08 PM   #5
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Brake Fluid Flush
Struts for leaks
Belts for cracking
Thanks guys. completely forgot about alignment!!!
tires are balanced.. i can do my own oil changes. But I don't have the tools to swap trans and diff so I need a shop to do it. I think i'm gonna go with Motul 300 for both.
Brake fluid is ridiculously difficult by my standards, the service manual says 48,000 it should be Replaced, so i'll guess i'll get a shop to do that at the same time as well. Hopefully I can get OEM brake fluid? I tried to get OEM tranny fluid from Toyota and they said they don't sell it.
Old 07-22-2015, 03:06 PM   #6
WhiteFRS69
WhiteFRS69's Avatar
the only tools you need to do the trans/diff is a 10mm hex key, some jack stands, 2 new crush washers,
if you are going with Motul 300, it has a filler on the bottle so you dont need a pump or anything
Old 07-22-2015, 05:18 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Not if it is an AT. It looks easier to lunch a nuke then change the AT fluid lol!!
Old 07-22-2015, 05:32 PM   #8
WhiteFRS69
WhiteFRS69's Avatar
lunch a nuke??? lol
Old 07-22-2015, 05:45 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
lunch a nuke??? lol
Originally Posted by Anorexic 86 View Post
If you plan on doing this yourself... good luck changing it out correctly.
The process is harder than launching nuclear missiles.
I remember reading the instructions and thinking... WTF!!!
IT'S NO JOKE AND NOT AS SIMPLE AS DRAIN AND REFILL!
Check out the online BRZ shop manual listed in the sticky section of this thread for the instructions.
Again... good luck.
Go find the thread on how to DIY its a good read.
Old 07-24-2015, 10:46 AM   #10
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
I replaced my tranny and diff fluid with motul gear 300 yesterday
The shifts feel pretty much the same as they did with the OEM fluid.. I was expecting a big difference... also there weren't that many shavings on the magnetic plug
next up is brake fluid
Old 07-24-2015, 02:56 PM   #11
radroach
Drives: car
@RickyRacer
By 50k miles I had tranny/diff fluid change, coolant flush, brake fluid change, engine cleaned at dealership (seafoam?).
Next things on the list are spark plugs, oem clutch replacement, and brakes.
Old 07-24-2015, 03:02 PM   #12
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Originally Posted by radroach View Post
@RickyRacer
nice man!
Is coolant flush really necessary though? I thought the coolant in this car can go for 8 years or 200k or something like that
Old 07-24-2015, 03:06 PM   #13
radroach
Drives: car
@RickyRacer no not required, just something for the dealership to stack up on the bill
Old 07-27-2015, 12:21 AM   #14
pantdino
Drives: Firestorm 2013 FR-S
Brake fluid is a time-related issue-- should be changed every 2 yrs regardless of mileage because it absorbs water from the atmosphere and will rust out your brakes from the inside.
QUESTION-- how many miles on your car or how long since it had been changed was it filthy? The one in my car is made of grey material so hard to tell if its dirty or not.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
maintenance light ricky rod Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-16-2015 04:23 PM
FR-S Maintenance Information FRSBRZGT86FAN Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 11-18-2014 11:22 AM
For those who do their own maintenance FR-S89 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-24-2014 11:03 AM
Cost of maintenance cys19 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 09-22-2014 01:50 AM
25,000 Where can I go for maintenance. laley81 Southern California 9 09-20-2013 04:00 AM
