Old 07-06-2017, 10:50 PM   #1
patseidon
Drives: 2015 FRS
Subframe and Diff Risers Install
Has anyone installed subframe risers and diff risers? Can someone direct me to a thread or walk me through it? Thanks in advance.
patseidon is offline   Reply With Quote
Old 07-06-2017, 11:53 PM   #2
15limited
15limited's Avatar
Solid mounts right?
http://www.partsshopmax.com/e107_plu...opic.php?19215
http://voodoo13usa.com/shop/2013-frs...rame-bushings/
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 07-09-2017, 06:40 PM   #3
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Yeah I have done it.
Old bushings are a bitch to get out.
if you do it yourself, be prepare to remove the whole rear end and for some welding, and various other mods.
The heat shields around the drive shaft can rub, you will need to either cut sections out, or massage them with a hammer.
And ones it's done, its not really reversible unless you buy a whole new subframe.
There is a thread somewhere on here about it.
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 07-09-2017, 08:44 PM   #4
15limited
15limited's Avatar
It was a big pain in the ass for me too as I don't have much, if any, experience or a shop full of tools for an extensive modification as this. OEM bushings can be tedious, unless you have laser precision accuracy with a sawzal or whatever cutting utensil you can bum off your buddy like I did. Unless you have gobs of patience and time to think yourself through the process and accumulate or borrow the proper tools I wouldn't recommend doing it yourself.
PBM Solid Diff and Subframe mounts install Thebadvibes__ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-23-2017 01:04 AM
Diff and subframe risers? Josh Ehlert Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-18-2016 07:22 AM
Axles Or PBM Subframe risers? nickmerronesucks Engine, Exhaust, Transmission 10 03-27-2016 12:51 AM
