Old 01-29-2016, 10:52 AM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Axles Or PBM Subframe risers?
What is a better solution? DSS Axles or the Powered by max subframe risers?
I'm at a standstill with deciding. Wonder if anyone had any experience with both or one or the other.
Any advice would be appreciated.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 01-29-2016, 10:53 AM   #2
-Phil
Drives: Rb25 neo brz
I went with the DSS axles for peace of mind. They are very well made and have a ton of support behind them.
-Phil is offline   Reply With Quote
Old 01-29-2016, 10:53 AM   #3
Cole
Not a troll
Cole's Avatar
I'd do the PBM stuff. Add in their LCAs, and they raise your hub up as well.
Old 01-29-2016, 10:55 AM   #4
nickmerronesucks
Ned flanders
I have their LCA's already. My car went from stupid stanced(tons of camber, 6 degrees) to factory spec's and Axle broke recently.
797Performance.com
Old 01-29-2016, 10:56 AM   #5
Cole
Not a troll
Cole's Avatar
Prolly the straw that broke the camels back, if you see what I'm getting at. If you're not putting down stupid power and aren't too low, you're probably ok with stock axles.
Old 01-29-2016, 11:00 AM   #6
nickmerronesucks
Ned flanders
The car is pretty low just not as low as it was(IE lip of wheels tucked in fenders on 18s), not it is more of a hair of clearance between tire(meaty ones now) and fender and is only at about 300hp.
797Performance.com
Old 01-29-2016, 11:03 AM   #7
DAEMANO
Time Traveller
DSS Axles do not solve in CV breakage problem. Subframe or diff risers will. The other choice is to only lower your car just a bit.
Old 01-29-2016, 11:11 AM   #8
Jdogg88
Drives: Sapphire Blue ‘23
I'm running the pbm subframe risers for almost a year now with no problems. My car is about 1 1/2 lower than stock, dz102 tires on stock wheels, and about -1.2 degrees camber. Every month or so, I check the axles and haven't seen any tears or leaks coming from the cv joints or heard any strange clicking noises that associates with breaking axles.
Jdogg88 is offline   Reply With Quote
Old 03-26-2016, 09:49 AM   #9
iamhubert
iamhubert's Avatar
Drives: 2013 frs
Did you just do the subframe risers or did you also pair it with the pbm diff riser bushings as well? I have the whole kit, but I'm debating wether to just do the subframe riser and pair it with the whiteline diff cradle and support insert, or if to do the whole pbm kit. I'm mainly questioning the idea of solid diff bushings, because from my understanding wouldn't or couldn't that hurt the drivetrain a bit being completely stiff?
IG: iamhubert
iamhubert is offline   Reply With Quote
Old 03-26-2016, 04:56 PM   #10
nickmerronesucks
Ned flanders
I went with all the white line inserts. feels pretty good so far
797Performance.com
Old 03-27-2016, 12:51 AM   #11
Jdogg88
I'm only using the subframe risers but will probably get the diff risers soon for more peace of mind.
Parts Shop Max subframe and differential risers philstar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 02-20-2024 11:05 AM
DSS Axles? nickmerronesucks Want-To-Buy Requests 6 02-01-2016 08:09 AM
Parts Shop Max Subrame and Diff Bushings/Risers AxisPower Brakes, Suspension, Chassis 2 09-27-2014 03:39 PM
Sub frame risers DavidBob Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-23-2014 09:02 PM
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-10-2014 08:59 PM
