Old 06-24-2017, 01:31 PM   #1
drz400dude
Turbo internal oil leak
I installed my works stage 2 a couple weeks ago and I noticed oil leaking from my down pipe to front pipe connection. There is no oil leaking externally so I don't know where else it could come from. It's not leaking much because I've been checking my oil and haven't noticed the level going down. Just weird I'm getting oil in my exhaust.
drz400dude is offline   Reply With Quote
Old 06-26-2017, 02:36 PM   #2
SirSpectre
Drives: 2013 Hot Lava FRS
Oil in the exhaust pipe indicates blown seals. Exhaust smoking a lot?
SirSpectre is offline   Reply With Quote
Old 06-28-2017, 08:54 PM   #3
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Or a blocked/pinched return line.
The Following User Says Thank You to Kiske For This Useful Post:
Guff (06-28-2017)
Old 06-28-2017, 09:16 PM   #4
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
If you have an improperly sized feed line (many BB turbos require restrictors), or an undersized/blocked drain line, you can get oil blowing out of the seals onto both the intake and exhaust sides.
Either that or the seals are bad on the turbo, which shouldn't be the case if it's new.
- The Ancient BRZ Sacrament
by Zaku
Internal/s capacity? Matey Engine, Exhaust, Transmission 8 02-13-2017 06:58 PM
OEM internal engine parts + unichip ndreim Engine, Exhaust, Bolt-Ons 3 06-22-2016 01:34 PM
FI rebuild tips internal mods? SoCal80six Forced Induction 18 11-14-2015 02:57 PM
boost and internal mods aquaman Forced Induction 15 03-13-2015 04:10 PM
Help me understand the internal WG on EFR bakerr6 Forced Induction 2 01-12-2015 05:33 PM
