Drives: Pearl White BRZ
Internal/s capacity?
I'm starting the actual process of dwindling down the FI kit that I will be finally buying later this year and I can't seem to find anything from searching so I'm hoping someone sees this and can lead me in the right direction. What is the limit of the stock motor with FI? I know I'll need pump/injectors (aiming for about 320-330 rwhp) but I'm more worried about rods, etc. Any notable power ranges that the engine becomes unstable or WILL break at 300+? Trying to get that out of the way by going ahead and buying if it's a possible issue.
TIA |
Drives: 2017 BRZ
I think people try to stay under 300whp for a "reliable" setup. I know some have gone well into the 350+ zone with no issues on e85. But thats just playing borrowed time at those levels if it isnt a dyno queen.
Drives: Toyota 86
I agree. People are pushing higher like to 400 stock but I think if you want to be able to drive it and enjoy it a without worrying if you will blow it 300 is a nice number.
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Thanks guys. Guess it's time to find out if I really want to spend the extra couple grand just to push my car to 330. at that point i'd probably shoot for 350
Drives: JRSC C38 HBP E85 FRS
I'd also consider the Tq curve you're shooting for. A smooth, linear curve from a centrifugal Supercharger will be less stressful to internals than a low end Tq monster like a roots/twinscrew blower. I used Superchargers as an example but turbos have different curves as well depending on the turbo size and kit designs. Horsepower isn't the top culprit for breaking things, torque is.
Drives: Late 2014 Subaru BRZ
Its all about your tune. My tuner didnt aim for instant torque so the car feels entirely stock at low rpm and low throttle under 3k. Tomuch low end torque does bend rods.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
Drives: 2017 BRZ
Excuse my lack of knowledge but...Does the low end torque make a difference when driving spiritedly, or is it strictly when below 3k or something? Let's say you're at 5k rpm, off throttle into a corner, then back onto throttle 100%. If the centrifugal and roots make the same torque at 5k rpm, will the engine take it the same?
#8 | |
The thing to consider is driveline shock. A smooth, linear flow of Tq is better than no throttle to 100% all of a sudden. All that being said, some people have catastrophic engine failure with the cruise control set just putting down a side street. There's been people have their engine go out bone stock. I wouldn't over think it. Bottom line, if you're worried about engine failure and don't have the means to replace your engine if you blow it, you probably shouldn't be bolting on 50% more power. I say, go for it👍🏻 |
Drives: 2005 Toyota Camry
200 to around 450+ HP. Give or take a few hundred.
| The Following User Says Thank You to mav1178 For This Useful Post: | D_Thissen (02-13-2017) |
| FI rebuild tips internal mods? | SoCal80six | Forced Induction | 18 | 11-14-2015 02:57 PM |
| Reducing internal EGR and throttling loss with VVT | serialk11r | Software Tuning | 13 | 06-28-2015 11:11 AM |
| boost and internal mods | aquaman | Forced Induction | 15 | 03-13-2015 04:10 PM |
| Help me understand the internal WG on EFR | bakerr6 | Forced Induction | 2 | 01-12-2015 05:33 PM |
| internal lighting color debate. help? | lbroskee | Cosmetic Modification (Interior/Exterior/Lighting) | 40 | 02-21-2013 03:04 PM |
