Old 11-11-2015, 12:00 PM   #1
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
FI rebuild tips internal mods?
Just blew my motor a few days ago looking for forged pistons, rods, ect.... don't believe I blew a rod from the block can't see any visual damage, or oil so most likely will be building on to my block. Let me know what's the best and safest route for internal that will hold some power.
SoCal80six is offline   Reply With Quote
Old 11-11-2015, 12:05 PM   #2
Andew727
Drives: Scion FR-S
I am in the same boat with you. just started the tear down this morning! Lets see what we can get thrown at us. right now im thinking about the full HKS stroker.
What FI kit? my plans are to completely redo the piping layout and mount for my HKS GT SC set up.
MODS:
HKS GT Supercharger
HKS S type Oil cooler
E85
FIC Injectors
DW65cc fuel pump
Stock and 95mm pulley
PLANS:
so far, keep oem crank with new rods, pistons etc.
cams and springs
reduce piping bends/enlarge intercooler
remount sc to drivers side vs directly in front of the intake
route air and improve cooling to oil cooler and sc traction cooler.
Andew727 is offline   Reply With Quote
The Following User Says Thank You to Andew727 For This Useful Post:
SoCal80six (11-11-2015)
Old 11-11-2015, 12:29 PM   #3
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
MODS:
HKS GT Supercharger
E85
FIC Injectors
DW65cc fuel pump
PLANS:
cams and springs
Are you going to be running same kit?
I am running maperformance kit with precision 5858 turbo, 850cc fic fuel injectors, dw65cc fuel pump , uel manifold, with map custom + 1.5qt oil pan. Also i am running a delicious flex fuel kit so will be running e85 again. Not to sure who I'm going to get tuned by this time though. Im not to sure which direction I will be going with it right now definitely rods, pistons, and most likely valves. Still have my options open definitely want to run around a 10.0 cr definitely looking for best internals don't want to have to deal with this again.
Sent from my SM-N920T using Tapatalk
Old 11-11-2015, 12:31 PM   #4
raven1231
Billet everything
FRS Justin (11-11-2015)
Old 11-11-2015, 12:35 PM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If you're not going v8, have an fa20 expert build it. My first choices would be grabow and full blown.
Old 11-11-2015, 12:43 PM   #6
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Just gave full blown a call they will definitely be in my top.
Old 11-11-2015, 10:46 PM   #7
FRS Justin
Drives: 2013 Asphalt FRS
Give Outfront Motorsports a call in Buena Park CA
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Old 11-11-2015, 10:47 PM   #8
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Thanks just gave them a call today they definitely know what their doing most likely will be working with them!!
The Following User Says Thank You to SoCal80six For This Useful Post:
raven1231 (11-12-2015)
Old 11-12-2015, 07:50 AM   #9
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Don't ignore the heads. Upgrade your valve springs at the very least!
The Following User Says Thank You to Draco-REX For This Useful Post:
SoCal80six (11-12-2015)
Old 11-12-2015, 08:25 AM   #10
Andew727
Drives: Scion FR-S
sort of the same kit. the only original pieces will be the compressor, traction fluid res, filter, i have seen the hks stroker kit with the V2 HKS set up making close to 400 whp. thats my goal.
Old 11-12-2015, 10:26 AM   #11
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We've done a few this year, and as stated above this is not an easy diy kind of thing. Don't skimp on the little stuff. Cometic gaskets, arp hardware, upgraded springs should all be standard build items. At high rpms if you float the valves rockers will shoot out the valve covers, and setting up the rings is critical on the horizontally opposed motors unless you want a good bit of oil consumption. Built right they should last a long time, but make sure to allow adequate warm ups when using forged components.
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
Kris86 (06-30-2016), SoCal80six (11-12-2015), xxscaxx (11-12-2015)
Old 11-12-2015, 06:18 PM   #12
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
This is perfect! Now I can take some notes
MS, CSCS, TSAC-F, CPT
Old 11-12-2015, 07:29 PM   #13
EAGLE5
Dismember
EAGLE5's Avatar
To be clear, there are lots of good shops out there. Evasive gets good reviews. Moto-East does too. Prime Motoring. Of course, in the end, any engine from any builder tunes by any tuner can pop.
Old 11-14-2015, 12:56 AM   #14
weederr33
weederr33's Avatar
In terms of the head gaskets, there's the Cometic, but I have seen the HKS and the Cosworth gaskets. Any thoughts on those?
Reducing internal EGR and throttling loss with VVT serialk11r Software Tuning 13 06-28-2015 11:11 AM
Cosworth Internal Upgrades Confirmed DanPO Engine, Exhaust, Transmission 60 05-26-2015 05:45 PM
boost and internal mods aquaman Forced Induction 15 03-13-2015 04:10 PM
Help me understand the internal WG on EFR bakerr6 Forced Induction 2 01-12-2015 05:33 PM
Saturday mods. Exhaust tips and a bazooka tube. Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 23 03-14-2013 10:24 PM
