Old 01-10-2015, 04:42 PM   #1
bakerr6
Drives: 2013 raven black fr-s
Help me understand the internal WG on EFR
So my experience with turbo has always been aftermarket, but all external wg with a spring. On my err turbo, it's internally gated and I'm trying to check what spring rate I need to have it rated at, but I'm confused.
What I'm seeing on the mid boost wg is that it can crack open as low as 8.8psi, but under full load would receive the 20.6psi. From what I'm seeing here, I think this means it will hold at 8.8psi as the turbo spools and will crack open at this pressure, but hold until 8.8psi (just like a traditional external wg). The 20.6 is just a reference for not trying to run more boost than this. Is this correct?
I have my failsafe hooked up, and it's reading between 9-10psi of boost, which is a little high for where I want to be, but I wanted to see if it would even make sense to adjust the wg.
http://www.full-race.com/store/image...-content-3.jpg
Chart for reference
bakerr6 is offline   Reply With Quote
Old 01-12-2015, 09:39 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If you want to run less than 9 psi, then you need to swap out to the low boost WG canister.
Old 01-12-2015, 05:33 PM   #3
bakerr6
Coil that's what I was under the impression of. Ty sir
Cosworth Internal Upgrades Confirmed DanPO Engine, Exhaust, Transmission 60 05-26-2015 05:45 PM
Products to recommend to repair internal plastic scratch impossible Cosmetic Modification (Interior/Exterior/Lighting) 7 10-10-2014 10:06 AM
I didn't like the AT and I'm trying to understand why fiveoneoh BRZ First-Gen (2012+) — General Topics 97 06-11-2013 01:34 PM
internal lighting color debate. help? lbroskee Cosmetic Modification (Interior/Exterior/Lighting) 40 02-21-2013 03:04 PM
What I just don't understand... Liquidcell Scion FR-S / Toyota 86 GT86 General Forum 35 08-30-2012 08:38 AM
