Drives: Genesis Coupe 2010
window squeaking noise
Got myself a 13 BRZ about 2 weeks ago. And every time I wash my car or when it rains, both driver/passenger's window starts to make squeaking sound every time I roll up and down. I've searched it and found out this is a pretty common issue that happens to a lot of people. I tried to find it's PERMENANT solution but failed. Please help me with this because it is very annoying
P.S: Will it eventually cause or damage on my windows if I just leave it as it is? I also heard using silicone grease spray would work but I have a feeling it's just a temporary solution where it occurs again if I don't do that regularly. Thank you very much in advance all. |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
It seems to have caused damage on my driver's window. My driver's window is the only one that squeaks for whatever reason, but it is LOUD, and it happens every time it's even so much as mildly humid outside, let alone when it rains.
Now my driver's side window has visible scoring in the glass from the tracks. They're deep enough that you can feel them with your fingernail.
@bpennerz
Drives: 2016 BRZ
I had the seals replaced under warranty and the window continues to squeal. For what it's worth, the dealership said Subaru is aware.
'16 BRZ
'07 Buell XB9R |
The Dictater
Drives: '13 Red Scion FRS
#5 | |
![]() I suggest you clean the glass real good (well) and treat the weather stripping (especially in the groove) with silicone. Works for my windows...... ![]() humfrz Last edited by humfrz; 06-22-2017 at 03:25 PM. |
#6 | |
http://www.ft86club.com/forums/attac...1&d=1389643313
#7 | |
Even if out of warranty it may be worth while having it done.
Off Topic
Subaru has been aware of this for decades. My 2000 Impreza had scratches on the windows from raising and lowering them, and it was a commonly acknowledged issue back then, too. That the issue hasn't been remedied by now means they know; they just don't care. It would interfere with their frameless windows.
Senior gif poster
Drives: 2013 Asphalt FRS
When my car was new the Windows squeaked all the time. Don't worry this does go away on its own. Mine stopped around 30k-40k can't say for sure but they never squeak now I'm at 65k and my window seals are all still working great. You can try adding a little wax on the windows inside and out which can help with the squeaking in the mean time.
#10 | |
Mine has been doing it since the day I got the car, with 983km on it. I am now at almost 110,000km, and almost 3 years later, and if anything it's actually worse now then it was before. Just don't want people getting the wrong idea, because this certainly does not "go away on its own". Maybe you just got lucky!
@bpennerz
#11 | |
But that of course will mean new lifters, new glass, labour... ![]() I might just have to live with it.
@bpennerz
#12 | |
Senior gif poster
#13 | |
Definitely happens more in the spring and summer, and being in Toronto, our winters are awful. It squeaks when it's not even wet outside; if it's just very humid, it will still squeak like a stuck pig. It's so loud sometimes that people standing OUTSIDE the car will look over. It's embarrassing.
@bpennerz
#14 |
Senior gif poster
Now that I think of it it stopped squeaking around the time I started covering and garaging the car when parked. So maybe it isnt fixed for me and just lying I wait. I do suggest some wax on the outside or even rain X, could lube the window just enough to not squeak. Hope you find something that works, good luck.
| Squeaking noise from the steering | ScionFR-S | Issues | Warranty | Recalls / TSB | 22 | 02-09-2018 05:37 PM |
| Window squeaking problem, really need help, how to fix? | Mask621 | Issues | Warranty | Recalls / TSB | 7 | 07-02-2015 07:32 AM |
| Squeaking noise from wheel | oinkoinkpig | Issues | Warranty | Recalls / TSB | 8 | 04-26-2014 11:10 AM |
| Squeaking noise | oinkoinkpig | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 12-25-2013 04:26 PM |
| Squeaking or squealing window | Cjm005 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 12-25-2012 12:19 AM |
