Old 12-25-2013, 04:24 AM   #1
oinkoinkpig
Drives: frs
Squeaking noise from wheel
First off I know the video is terrible but this is just a midnight cry for help. I'll obviously take it to a mechanic to diagnose the problem but since it happened on Christmas eve I can't do much about it at the moment. I just want to see if anyone experienced this in their previous cars or what not.
This high pitch noises occurs when the car is moving. It also happens when the car is idle and pressure is applied downwards against the car. I don't think its brakes. Wheel bearings?
http://s154.photobucket.com/user/dea...32f49.mp4.html
Link is to the video. Any comments would be appreciated.
oinkoinkpig is offline   Reply With Quote
Old 12-25-2013, 08:04 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Wow. That's really weird. It sounds like that noise you get from worn out pads. I don't think it's a wheel bearing, usually a wheel bearing noise is like a humming noise. Maybe a suspension part broke or there's something stuck in the wheel area causing that squeak.
Old 12-25-2013, 09:30 AM   #3
SteveGrillo
Drives: Brz
If you can push down on the car and the sound happens, I'm thinking it should be very easy to isolate the squeak. It does sound metal on metal. Maybe a shock went bad? Does the squeak happen equally on all four corners when you push down on each corner? Or is it just on one corner?
SteveGrillo is offline   Reply With Quote
Old 12-25-2013, 11:26 AM   #4
Pete156
I like to eat!
How many miles on the car? Check your right rear brake pads. My best guess...
Pete156 is offline   Reply With Quote
Old 12-25-2013, 04:13 PM   #5
humfrz
Originally Posted by oinkoinkpig View Post
........This high pitch noises occurs when the car is moving. It also happens when the car is idle and pressure is applied downwards against the car. .....
So, are you saying that the noise also happens when the car is NOT moving .. ??
humfrz
Old 12-25-2013, 05:55 PM   #6
fistpoint
Drives: Supercharged Golf Cart
I often hear a tiny squeak from the front brakes when backing out of my garage for the first time after a couple nights of being parked. Only the initial backup, no more sound after warmup.
fistpoint is offline   Reply With Quote
Old 12-25-2013, 06:15 PM   #7
oinkoinkpig
Drives: frs
I believe it's fixed for now. I brute forced it by driving it for a few km. The noise is gone now and hope it's just a rock wedged between or something...Thanks everyone
Old 12-25-2013, 08:56 PM   #8
N1rve
N1rve's Avatar
I don't see a thanks on my post....
Just kidding
Old 04-26-2014, 11:10 AM   #9
Dpforlife
Dpforlife's Avatar
Drives: Scion FR-S Raven
Mine just started doing this last night than it stopped. Hope it doesn't come back!!
Dpforlife is offline   Reply With Quote
Squeaking noise oinkoinkpig Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 12-25-2013 04:26 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
Squeaking Noise From Steering Wheel tonytduc Scion FR-S / Toyota 86 GT86 General Forum 4 01-28-2013 07:58 PM
weird plastic squeaking noise (back seats) whyreeto AUSTRALIA 5 09-17-2012 01:34 AM
