Old 06-04-2017, 07:50 PM   #1
Benzin
Benzin's Avatar
Lithium Ion Battery Replacement
Was wondering if anyone has tried replacing the traditional chemical car battery with a lighter Lithium ion Battery, and if it's recommended at all?
Benzin is offline   Reply With Quote
Old 06-05-2017, 12:59 AM   #2
zeal86
zeal86's Avatar
Drives:
I have the Shorai... When cared for properly it is a solid alternative... It is Lithium-Iron though.
Here is the link http://shoraipower.com/lfx36l3-bs12-p130
Also, I believe others have used the Braile brand battery... Not sure what the model number is though.
I purchased my Shorai with a very nice mounting kit from Kinetic Custom Machine... The whole assembly weighed like 6.5 lbs. Not sure if KCMachine are still in business though.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 06-05-2017, 01:04 AM   #3
Benzin
Benzin's Avatar
Looks good, I'll check it out.
I'm looking more towards reducing weight and getting rid of that yucky corrosion around the terminals.
Sent from my Nexus 6P using Tapatalk
Old 06-06-2017, 11:18 AM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I've run the Odyssey PC680 and PC925 batteries with great success. They are AGM's though.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 06-06-2017, 11:41 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Water, baking soda, 2 minutes of elbow grease.
Old 06-06-2017, 11:55 AM   #6
Benzin
Benzin's Avatar
But that sweet weight reduction!
Old 06-06-2017, 12:12 PM   #7
skogs
Drives: GT86 2013
I think a LiFePo4-battery is what you want. Safer and more stable at low and high temps then lithium ion.
This for instance:
https://www.ev-power.eu/LiFeYPO4-bat...LP12V40AH.html
Way more usable capacity then stock, half the weight.
skogs is offline   Reply With Quote
Old 06-06-2017, 12:24 PM   #8
humfrz
.......and then they got pretty colored stuff you can spray on the terminals to retard corrosion.
I'll be damn if I'd install a lithium ion battery in my car .... I done saw on TV what even the little ones can do to cell phones ....
humfrz
Old 06-06-2017, 12:42 PM   #9
Benzin
Benzin's Avatar
This for instance:
Wow that is pretty light. Think we found a winner. Thanks very much.
Old 06-06-2017, 12:45 PM   #10
Benzin
Benzin's Avatar
humfrz
Yes, that pretty colored stuff and a wire brush is what I use now. It gets annoying honestly.
Oh noes ma' cah gonna blow from a little old bettery and not from the tank full of combustible liquid :eek:
Old 06-06-2017, 12:52 PM   #11
zeal86
zeal86's Avatar
Drives:
humfrz
The Shorai batteries are Lithium-Iron which according to what I've read about the differences between LiFePo4 and LiCoO2 (Lithium-Ion) when it comes to stability and safety are as follows:
--The lithium-iron (LiFePo4) battery has a slight edge over the Li-ion (LiCoO2) battery for safety. This is important because a battery should not get overheated or catch fire in case of overcharging.
The lithium-iron battery has superior chemical and thermal stability. A Lithium-iron battery remains cool at room temperature while the Li-ion may suffer thermal runaway and heats up faster under similar charging conditions.--
Article link can be found here http://www.newcastlesys.com/blog/lit...iron-batteries
It probably wouldn't change your mind about using Lithium batteries but I wanted to make the difference clear for others that are considering.
Old 06-06-2017, 12:54 PM   #12
zeal86
zeal86's Avatar
Drives:
This for instance:
+1 Missed this post... I basically posted the same info.
Old 06-06-2017, 01:35 PM   #13
stevesnj
stevesnj's Avatar
I dunno how many amps our alternators put out to the battery but this https://www.ev-power.eu/LiFeYPO4-bat...LP12V40AH.html maxes at 40 amp. You should check on this to be sure. Those batteries will burn like a plasma cutter not explode
My 2016 Build thread
Old 06-06-2017, 01:36 PM   #14
humfrz
Thanks for the information.
I was "jest ah messen wich" the concept ......
I'm a little out of touch, since most of my machines used a magneto .......
humfrz
Shorai Lithium Iron Battery w/ Terminal 21AH 3lbs LFX21L6-BS12 - $100 customfab87 Audio/Visual, Electronics, Infotainment, NAV 3 11-02-2016 08:57 PM
Pulse P3 Lithium Ion battery in Evasive's FR-S Evasive Motorsports Tracking / Autocross / HPDE / Drifting 15 07-11-2013 05:03 PM
FS: New Shorai Lithium-Iron Lightweight Battery (LFX36L3-BS12) ft86Fan Interior Parts (Incl. Lighting) 0 06-11-2013 01:54 PM
Lithium Ion Battery Flat Black VW Scion FR-S / Toyota 86 GT86 General Forum 1 11-09-2012 02:23 PM
Lithium battery questions TuxedoCartman Electronics | Audio | NAV | Infotainment 2 11-07-2012 04:51 PM
