Drives: 2014 FR-S 6MT
Shorai Lithium Iron Battery w/ Terminal 21AH 3lbs LFX21L6-BS12 - $100
Super light weight (3lbs) Shorai lithium battery. Gently used in a daily driver in Southern California. Has 315CCA, so about 400 at room temperature. 21AH capacity is plenty to listen to the radio while working on the car. Behaves just like a normal lead-acid battery, but is 28lbs lighter!
Posts are already set up for a FR-S/BRZ. Added a battery post to the negative terminal, which cost another $10. I found that the positive terminal post doesn't fit as well. Instead just unbolt the cables from the terminal post clamp and bolt them directly to the battery. Red positive terminal cover fits on just fine. Battery tie-down works perfectly flipped upside down. $100 + Shipping Last edited by customfab87; 11-02-2016 at 01:41 AM. |
#2 | |
Site Moderator
Drives: ichi 86 Project
Please follow the Member Classified Rules (#2) or I'll delete the thread.
ichi |
Sorry about that. Fixed. Price drop to $100.
Drives: Civic Hyb, RS6, BRZ SeriesBlue
Does the car need any modification or additional accessory to use this battery?
This is the quote from Shorai's website, " SHORAI LFX Lithium-Iron Powersports battery, 21Ah PbEq 12V eq, "L" polarity, Case Type 6 Length 5.83" Width 3.23" Height 5.51" Shorai Batteries require a charging system output of 13.1 Volts or higher at idle, and must not exceed 15.2 volts at maximum output." |
| 3.6oz Carbon Fiber Battery Bracket for Shorai LFX21L6-BS12 | Anthony | Tracking / Autocross / HPDE / Drifting | 5 | 04-02-2020 02:48 PM |
| KC Machine Tray and Shorai battery + Shorai Charger | toeout | Engine, Exhaust, Bolt-Ons | 0 | 02-15-2015 05:34 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
| FS: New Shorai Lithium-Iron Lightweight Battery (LFX36L3-BS12) | ft86Fan | Interior Parts (Incl. Lighting) | 0 | 06-11-2013 01:54 PM |
| Lithium Ion Battery | Flat Black VW | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-09-2012 02:23 PM |
