Old 10-04-2016, 11:54 AM   #1
FX86
Car swaying left right (floating feeling) highway speeds
Lately I noticed on highway speeds 60-65mph (higher if i'm following the flow of traffic in the fast lane) my fr-s feels as if it slightly swaying side to side almost as if the wind was blowing it really hard making it feel as if the car is floating
tires are inflating up to spec of 35psi...alignment was done earlier this year...car is fully stock mechanically speaking. 2015 w/ just under 25K miles
any ideas? probably need to get another alignment?
Old 10-04-2016, 11:56 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
It is a light car so could be just the wind maybe??
maybe ruts in the road??
Old 10-04-2016, 12:00 PM   #3
FX86
it happens taking the highway to work and back everyday so far i noticed..tried different lanes just as a test and experienced the same thing
almost feels as if the car will snap the steering wheel feeling unstable...the best way i can compare it is as if i was driving on gravel
Old 10-04-2016, 12:03 PM   #4
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
alignment?
Tofurky is offline   Reply With Quote
Old 10-04-2016, 12:03 PM   #5
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
That sounds like an alignment issue to me. If it was an older car I would suggest checking your bearings, because a worn/failing bearing would cause the same thing to occur (for the same reason, as it basically allows the hub to move around causing your alignment to constantly change.) I wouldn't bother chasing down other issues until confirming that the alignment is correct. It's possible you don't remember hitting a bump, but maybe you did hit something that threw the alignment off, or slightly bent a tie rod or something. Sounds like a classic case of poor alignment.
Stang70Fastback is offline   Reply With Quote
Old 10-04-2016, 12:09 PM   #6
FX86
come to think of it there was this speed bump on a neighborhood road (i was not familiar with) that didn't really seem like a speed bump...it looked like small incline in the road as if it was recently patched but when i went over it i felt the car slammed down pretty hard so that might have been the culprit
i'll have the alignment checked first
'ppreciate it!
Old 10-04-2016, 12:43 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah maybe its the alignment
Old 10-04-2016, 01:07 PM   #8
humfrz
'ppreciate it!
Good plan .......
humfrz
Old 10-04-2016, 01:28 PM   #9
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
+1 for alignment. I had my rear toe adjustment knocked out on one side and it felt like I was driving on ice.
BirdTRD is offline   Reply With Quote
Old 10-04-2016, 03:42 PM   #10
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Sounds like an alignment. If you've put on a lot of miles since this issue began take a look at your tread wear in the meantime to see if it's uneven on an edge, or if it's cupping/feathering.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 10-04-2016, 04:20 PM   #11
FX86
i had a F150 rental for a month then when i got my fr-s back the steering felt stiff in a good way and it handled like it was on rails (had my fr-s back now for almost a month so i didn't put a lot of miles on it...handling was fine when i dropped it off at the body shop)...started noticing last week the swaying and the steering started to feel loose but i'm thinking my muscles got used to the tighter steering of the fr-s again versus the lightweight steering of a F150
i'll check out the tire tread too and make sure everything looks proper
Old 10-04-2016, 06:25 PM   #12
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Could be tramlining as well. http://www.tirerack.com/tires/tirete....jsp?techid=47
I experience it on specific sections of the highway I commute. Usually sections with those parallel grooves vs flat asphalt.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 10-04-2016, 10:14 PM   #13
Originally Posted by Atmins View Post
write my essay
essay writer
http://luxuessay.tk/
write my paper
essay writing
academic writing
essay for you
paper writer
best essay writing service
write my paper for me
essaywriter
edit my paper
writing a paper
paper help
research paper writing service
essay helper
writing assignments
cheap essay writing service
essay writers
online essay writer
write essays for money
pay for essay
term papers for sale
thesis writer
write my thesis
writing essays for money
essay writers for hire
cheap custom research papers
college essay service
pay for essays
buy nothing day essay
buy term papers online
custom research paper writing
buying essays
do my research paper
help writing a paper
professional paper writers
write essays for me
essay helper online
dissertation assistance
write me a paper
write research paper
online assignment help
speechwriters
essay writers online
cheap paper writing service
buy an essay online
editing essays
write my term paper
help writing a research paper
write paper online
need help writing a paper
paperwriter
help with research paper
college essay writing help
help with essay writing
help me with my essay
academic writing service
online essay writing
essay edit
best essay service
cheap essay writing
where can i buy an essay
free essay writing service
writing paper online
do my essay for me free
hire essay writer
write an essay for me for free
help me write my essay for free
best college paper writing service
buying an essay
write thesis
best online essay writing services
buy an essay online cheap
write essays online
write research paper for me
term paper service
custom written papers
how to write an about me essay
thesis website
help writing papers
help writing essays
paper assistance
letter editing
the best essay writing service
help writing papers for college
good academic writing
help me write a thesis
college application essay writing service
help with thesis
cheap custom essays
eassy writing
free paper writing service
write me an essay free
reliable essay writing service
write my research paper for me for free
write college essays for money
college paper writing services
academic writers online
write my essay for cheap
college paper help
essay helpers
i need help writing an essay for free
essay writing sites
research paper editing
cheap essay writer
write papers for me
websites to write essays
assignment writing services
help writing research paper
purchase essays
professional letter writing services
essay help online free
essays help
college essay help online free
write my research paper online free
help me write a research paper
buying a research paper
research paper help online
write essay for me free
buy research papers online no plagiarism
help writing a paper for college
write essay for money
professional research paper writers
website to write essays
essays writing
affordable essays
help with essays
thesis writing services
buy dissertation online
buy essays for college
pay for a research paper
buy a research paper online
help me write my research paper
buy assignments
buy a dissertation
write me a essay
cheap research papers for sale
purchase essay online
essay writing assistance
help writing paper
buy custom research papers
thesis writers
write essay online free
i need a paper written for me
websites that write papers for you for free
help me write my paper for free
cheap essay help
cheap essays online
help with writing a research paper
pay to write my essay
order research paper online
college essay assistance
buy an essay cheap
where can i buy a research paper
help me write an essay for free
best assignment writing service
top 10 essay writing services
top essay writers
write papers online
research paper assistance
practice essay writing online free
need essay written
can you write my essay
cheap term papers
buy essay paper
order essays online
buying a research paper for college
helpwithassignment
purchase essays online
research paper website
cheap research paper writers
buy thesis paper
pre written essays for sale
buying essay
help with writing a paper
write my assignment for me
top rated essay writing service
cheap essay service
buy my essay
cheap custom essay
essays for sale online
custom dissertation
buy an essay paper
i need help with my essay
buy a term paper online
essays online to buy
help write my paper
order an essay online
research papers writing
websites for essay writing
pay for assignments australia
mba essay writing service india
paper writing online
assignment company
best website for writing essays
buy essay now
how to write an essay about my life
academicwriting
pay for paper writing
pay for assignment
custom dissertation services
help with assignments uk
best essay writing websites
help with term papers
write paper online free
my father essay writing
my favorite writer essay
edit letter
how to write a hiring letter
academia writers
cheap thesis binding
pay essay writing
essays buy
how to write a letter to a hiring manager
pay for dissertation
write my cover letter for me
term papers for sale online
buy a essay online
mba essay service
my future essay writing
cheap essay online
academia writing
affordable essay writing
academic writing support
my childhood essay writing
my best friend essay writing
help me with my essay free
assignment sites
pay to do my assignment
buying a term paper
cheap paper writing services
academic writing online
how to write an essay about my family
cheap paper writing
pay for essay writing uk
pay for term paper
help me with my research paper
academicwriters
dissertation writers online
i need help with my research paper
affordable thesis writing
buy cheap essays online
academic writing article
assignment website
order research papers
help me with my paper
buy essay online uk
how to write my thesis
write my essay help
free research papers sites
write essay service
academic writing uk
term papers help
my family essay writing
writing dissertation service
teach me how to write an essay
paper writing websites
best essay writers online
online thesis writing
buy essay service
academic writing services uk
eassy help
essay buy online
help with my assignment
pay to do assignment
purchase term paper
write research papers
affordable dissertation writing
online assignment writer
academic writing blog
help with assignments australia
buy an assignment
writing paper online free
cheap dissertation help
i need help with my assignment
my friend essay writing
assignments for sale
academic writing terms
pay for assignments
do my term paper
college essay for sale
essay writing help free
buy a custom essay
academic writing is
help with essays for free
term papers writing service
essays done for you
my mother essay writing
term papers writing
help with papers
affordable term papers
get assignments done online
money can t buy everything essay
pay for research papers
Don't think it is alignment. I think you just need a good essay. This guy can help.
Old 10-04-2016, 10:20 PM   #14
humfrz
DANG ..........I think his keyboard is stuck ......
humfrz
BRZ not stable at highway speeds unplugged Issues | Warranty | Recalls / TSB 70 11-20-2020 09:16 AM
Floating feeling DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 67 05-07-2017 10:57 AM
Average speeds on the highway? Yamajee Scion FR-S / Toyota 86 GT86 General Forum 67 09-29-2013 12:41 AM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 02:41 PM
