Old 05-20-2017, 12:42 PM   #1
skogs
Drives: GT86 2013
GT86 Bang for the Buck Build
My GT86-adventure finally started today. A completely stock 2013 auto with only 15 000 km on it. A perfect baseline to start with.
This car handles so incredibly well, and at the right rpm it's actually not that bad performance-wise. Even with an extra set of wheels in the trunk.
I do however feel that torque-dip everyone is talking about.
The only planned mods for the engine will be OFH, OFT and a drop-in filter.
Weight saving is next. Removing the spare tire and replacing the stock header with the lighter OFH will shave off quite a few kg's. Next thing on the kg/money-scale is a lighweight battery. I am putting together a LiFePo4/supercap-hybrid which will weight under 4kgs and cost around 150usd.
So: Header, filter, tune, lightweight-battery. Whats next on the bang/buck-list?
skogs is offline   Reply With Quote
Old 05-20-2017, 02:10 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Car and Driver weight reduction are fairly cheap too!
MS, CSCS, TSAC-F, CPT
Old 05-20-2017, 02:14 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
E85 or flex fuel tune
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
TheWhiteWizard13 (05-20-2017)
Old 05-20-2017, 02:59 PM   #4
SlowCarFast
Drives: 2015 BRZ Limited
The next thing I would recommend is wheels+tires followed closely by brake pads and fluid. You can shave off a few lbs of unsprung weight per corner and get a huge boost in grip. You will then want better brakes to make sure you can use all that grip with no fade worries.
You are taking a similar approach to me when I start my budget track build. I plan to do all of the same with the addition of wheels+tires, replace all fluids, brake pads, and oil cooler. I plan to do the fluids and oil cooler first because I like a healthy car and then tires+brakes because I like not dieing. Then add power.
SlowCarFast is offline   Reply With Quote
Old 05-22-2017, 07:51 AM   #5
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
^ This. If you already plan on getting the OFT, just go E85! 20+hp for free!
http://www.ft86club.com/forums/showthread.php?t=67310
BigTuna is offline   Reply With Quote
The Biggest Bang for the Buck Juwls92 Scion FR-S / Toyota 86 GT86 General Forum 36 01-20-2016 04:48 AM
Turbo Build - Goal 300whp at best bang for buck SON1C Forced Induction 32 10-21-2015 03:45 PM
Best bang for my buck? ric342 Southern California 12 02-14-2015 07:09 PM
best bang for the buck HFC BlackyRose Engine, Exhaust, Transmission 11 08-25-2014 10:19 AM
Most bang for the buck? GIMMICK Scion FR-S / Toyota 86 GT86 General Forum 24 05-07-2013 07:10 PM
