| Member's Car Journals Car journals by our members. |
Drives: GT86 2013
GT86 Bang for the Buck Build
My GT86-adventure finally started today. A completely stock 2013 auto with only 15 000 km on it. A perfect baseline to start with.
![]() This car handles so incredibly well, and at the right rpm it's actually not that bad performance-wise. Even with an extra set of wheels in the trunk. I do however feel that torque-dip everyone is talking about. The only planned mods for the engine will be OFH, OFT and a drop-in filter. Weight saving is next. Removing the spare tire and replacing the stock header with the lighter OFH will shave off quite a few kg's. Next thing on the kg/money-scale is a lighweight battery. I am putting together a LiFePo4/supercap-hybrid which will weight under 4kgs and cost around 150usd. So: Header, filter, tune, lightweight-battery. Whats next on the bang/buck-list? |
#2 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Car and Driver weight reduction are fairly cheap too!
#3 | |
TRACKBREAD
E85 or flex fuel tune Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | TheWhiteWizard13 (05-20-2017) |
#4 |
Drives: 2015 BRZ Limited
The next thing I would recommend is wheels+tires followed closely by brake pads and fluid. You can shave off a few lbs of unsprung weight per corner and get a huge boost in grip. You will then want better brakes to make sure you can use all that grip with no fade worries.
You are taking a similar approach to me when I start my budget track build. I plan to do all of the same with the addition of wheels+tires, replace all fluids, brake pads, and oil cooler. I plan to do the fluids and oil cooler first because I like a healthy car and then tires+brakes because I like not dieing. Then add power. |
#5 |
Drives: 2013 WRB BRZ
^ This. If you already plan on getting the OFT, just go E85! 20+hp for free!
http://www.ft86club.com/forums/showthread.php?t=67310
| The Biggest Bang for the Buck | Juwls92 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 01-20-2016 04:48 AM |
| Turbo Build - Goal 300whp at best bang for buck | SON1C | Forced Induction | 32 | 10-21-2015 03:45 PM |
| Best bang for my buck? | ric342 | Southern California | 12 | 02-14-2015 07:09 PM |
| best bang for the buck HFC | BlackyRose | Engine, Exhaust, Transmission | 11 | 08-25-2014 10:19 AM |
| Most bang for the buck? | GIMMICK | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 05-07-2013 07:10 PM |
