Old 05-16-2017, 08:15 AM   #1
dattran86
Driver
Drives: 2013 Whiteout FRS
Short grind after switching to Amsoil
Previously I had Motul Gear 300 in the Transmission, and everything was perfectly fine after 20K KM and 5 track days.
I've heard good thing about Amsoil products from a lot of different people. so I wanted to try it out.
last night I switch to Amsoil Severe Gear 75W-90 (SVG) GL5 for the transmission, and after my drive home, I noticed a short grind from 3rd - 4th and 6th - 5th.
Does anyone else run into the same issue?
Should I give it a little bit more time to break in? before deciding to switch back to my trust worthy Motul
Thanks
Edited: Did some research and found that I should use GL3 or 4 in the Transmission. Which is what I had before. Motul Gear 300 75w - 90 non LS. Wasted $70 bucks on Amsoil oil
dattran86 is offline   Reply With Quote
Old 05-16-2017, 01:49 PM   #2
humfrz
Thanks
First off ....... if it ain't broke ...... don't fix it .......
Second off ....... ......
Third off ........ I'll give you credit for having guts enough to post what you did .......
humfrz
Old 05-16-2017, 01:53 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Switch it back.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-16-2017, 02:05 PM   #4
dattran86
Driver
humfrz
thats life, you make mistake and learn hahaha
Old 05-16-2017, 02:06 PM   #5
dattran86
Driver
Originally Posted by 8RZ View Post
Switch it back.
yup, just bough new Motul oil. going to switch it back tonight.
Old 05-17-2017, 09:43 PM   #6
Poodles
Drives: 2015 Series.Blue
Wrong Amsoil fluid. That stuff is for the differential, not the trans. You would want "Manual Transmission & Transaxle Gear Lube 75W-90"
GL5 is too slippery for Aisin transmissions.
Old 05-17-2017, 10:19 PM   #7
dattran86
Driver
Updated:
Changed out the fluid myself yesterday right before my track day.
went back to Motul gear 300.
everything is perfectly fine now.
and I contact my Mechanic, he indeed put in Amsoil 75W-90 GL4-5 in the transmission and GL5 servere gear into the dif.
He gave me 2 extra left over bottle from the fluid change. so I was mistaken him putting for putting GL5 Servere gear into my transmission.
however according to my conversation with my mechanic, he told me it was because my transmission was bonded with Motul, so it will take some heat cycle for the Amsoil to break in.
All that being said I will stick to Motul from on.
Gear Oil :) Amsoil Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-12-2015 12:41 AM
Amsoil 75w-90 Man. Trans Oil Kody Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 10-28-2014 04:34 PM
Changed from stock to Amsoil gear oil...short grind now from 6-5 CaptainSlow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 08-12-2014 05:11 PM
Question for oil junkies regarding Amsoil OE vs Amsoil Signature Simon99 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-25-2014 10:48 AM
Amsoil sanmarcosfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-11-2013 09:10 AM
