Old 11-09-2015, 03:55 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Gear Oil :) Amsoil
Just to confirm, is it good what I am doing?:
for the Manual Transmission I shall go with:
https://www.amsoil.com/shop/by-produ...?code=MTGQT-EA
and for my differential I am good with:
http://www.amsoil.com/shop/by-produc...?code=SVGQT-EA
The differential I did not go with the LSD fluid. Am I okay as well?
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 11-09-2015, 04:05 PM   #2
swarb
You've been here long enough to know how to search.
Old 11-09-2015, 06:37 PM   #3
Mikeez
Engineering Student
I rather ask
Old 11-09-2015, 06:49 PM   #4
swarb
Originally Posted by Mikeez View Post
Considering the Amsoil 75w90 or 75w85 oil for the gear
I'm a manual transmission, should I go with this transmission oil change? Or motul?
Daily driven Canada weather must be considered
Last question for the differential should I go with LSD oils considering our car is a LSD lol?
You are a manual transmission?
Your car is a lsd?
Old 11-09-2015, 06:56 PM   #5
Mikeez
Engineering Student
Your car is a lsd?
Yes, shall I buy this for both differential and transmission?
Old 11-09-2015, 06:59 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Did you read the manual? Or search?
Joking aside its up to you. Asking which brand is like asking what kind of underwear you should buy. Lots of people will tell you to wear a g-string others will tell you to stay with boxers. In the end it's your call.
Old 11-09-2015, 07:19 PM   #7
Mikeez
Engineering Student
Hahaha,
I just went with Amsoil non lsd.
Old 11-09-2015, 10:11 PM   #8
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Yeah. All those oils are far better than the OEM stuff. Me personally I go with Redline oil. Only because I can get them cheaper at local auto parts store.
Old 11-10-2015, 05:27 AM   #9
roddy
roddy's Avatar
Drives: '13 Ultramarine
I wouldn't use Severe Gear in the transmission. It will be fine for the rear end though. If you want to use an Amsoil 75W90 in the trans, this is the one to use...
Old 11-10-2015, 08:08 AM   #10
Tekno Virus
Drives: 2015 Subaru BRZ Limited
I would recommend Motul 300, if nothing else the bottle nozzle will make it as easy as changing your engine oil.
Just remember that when the transmission (and the car) is cold, you'll have to coast really slowly and double clutch to go to second gear, and that will be with any oil.
You could also check out Millers Oil EE Transmission 75w90 oil.
Tekno Virus is offline   Reply With Quote
Old 11-10-2015, 05:47 PM   #11
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
^ Short shifter makes this even harder fucking 2nd gear lol
fumanchu1 is offline   Reply With Quote
Old 11-10-2015, 06:04 PM   #12
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Motul 300 gear oil is great because you can buy 4 bottles of it and use it for both the Trans and Diff fluid change. Got mine switched when I got my 30k service done.
Instagram: trevor.parque
Old 11-10-2015, 07:24 PM   #13
Mikeez
Engineering Student
So I cannot use severe oil in my transmission
Old 11-10-2015, 07:37 PM   #14
roddy
roddy's Avatar
Just saying I wouldn't do it myself...the EP additives that make it a good differential lube may not be good for the transmission.
Amsoil synthetic manual transmission gear lube 75W-90 used oil analysis mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 11-15-2015 05:39 AM
AmsOil/Motul oil flush... increased mileage? aznatama Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 01-28-2015 09:53 PM
Changed from stock to Amsoil gear oil...short grind now from 6-5 CaptainSlow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 08-12-2014 05:11 PM
Where to get Motul Gear 300 in the GTA? automatic CANADA 5 04-09-2014 04:48 PM
