Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 05-14-2017, 03:19 PM   #1
Speedinbai
Drives: 2017 brz
Headers and inspection in ny
Does anyone have a decatted header and passed inspection in ny. I really want to get ace headers in the future but swapping them in and out for every inspection seems crazy.
Sent from my SM-T810 using Tapatalk
Speedinbai is offline   Reply With Quote
Old 05-14-2017, 05:09 PM   #2
Harlock
Drives: 2017 BRZ
Got a catless header, front pipe with a high flow cat, I passed inspection. I think it's fine as long as you have at least 1 cat.
Harlock is offline   Reply With Quote
Old 05-15-2017, 08:14 AM   #3
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
With a header you'll need a tune anyways. Most ECM tuners can disable the P0420 code when you go catless.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 05-15-2017, 02:21 PM   #4
Speedinbai
Drives: 2017 brz
So it will still pass inspection without the cat
Old 05-15-2017, 08:48 PM   #5
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
it should because there is no sniff test just an emissions ready status. But I would wait for someone who is catless to chime in. I like to have at least one cat, which is usually a high flow one. 5HP not worth the smell.
Ernest72 is offline   Reply With Quote
Old 05-15-2017, 09:26 PM   #6
Speedinbai
Drives: 2017 brz
I would probably keep the second cat anyway I just know that the first cat is the one that determines the results from the obd2 test
Old 05-16-2017, 12:11 PM   #7
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
Look for harry at L&M auto service 4025 Astoria Blvd New York NY 11105, for NY inspections, tell him ciri(si~ri) sent you.
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 05-17-2017, 11:07 AM   #8
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
OP don't worry you will pass if you get a tune to remove the CEL. More than likely you will get a tune with the ACE because it is worthless if you don't.
Old 05-17-2017, 02:47 PM   #9
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I thought with a proper tune, going catless doesnt have the terrible smell?
PandaSPUR is offline   Reply With Quote
Old 05-17-2017, 07:04 PM   #10
Ernest72
Well then alot of subies have some bad tunes. I smell the catless guys without any issues.
Old 05-17-2017, 08:24 PM   #11
Speedinbai
Drives: 2017 brz
Yea definitely would get a tune. Now just need to save some money and I'm in business 😎😀
Old 05-17-2017, 09:31 PM   #12
PandaSPUR
PandaSPUR's Avatar
Would you really be surprised if all those guys had no tune or some off the shelf tune?
I was doing some research a while ago, mostly on other forums, and everything I read pointed to minimal if any smells with a tune.
Kinda makes sense since cats are meant to convert unburnt hydrocarbons, carbon monoxide, and nitrogen oxides. The only one of those three with a smell is unburnt hydrocarbons, so if your car is tuned so it doesnt run too rich or too lean, that should help?
No personal or expert experience on this stuff, just repeating what I've found online. Would be nice if someone without cats and with a tune gave their experience.
Old 05-17-2017, 10:11 PM   #13
Speedinbai
Drives: 2017 brz
There still is at least 10% unburnt fuel so it would probably be worse without a tune but you would still smell it. Not sure on how much of a difference that would be though
Old 05-18-2017, 08:09 PM   #14
Ernest72
Smell or no smell, you lose 5HP at best with a high flow cat. Unless its a racer, as a DD I would have one cat on there.
VA inspection VABeachBRZ Mid-Atlantic 1 10-10-2016 09:37 PM
OFT and inspection NyC Zn6 NY / NJ / CT / PA 10 08-18-2014 08:12 AM
OFT and inspection in NYC NyC Zn6 Software Tuning 6 08-15-2014 03:27 PM
Anyone know a guy for NY inspection? ZionsWrath NY / NJ / CT / PA 3 02-14-2014 10:06 AM
Inspection of New FR-S Still Tripped Scion FR-S / Toyota 86 GT86 General Forum 22 03-28-2013 07:19 PM
