Car Dilettante
Drives: Nikki
Wheel and tire specs for FRS (New Tein Flex Z suspension installed)
Hey everyone!
Very new to FT-86 but I like community here so far from reading many threads. I just installed new coilovers on my FR-S and I am trying to find out what wheel and tires specs are flush to fit and be able to withstand speed bumps without scraping! I hope to hear everyone's solution! Victor
Don't give up. We still have road ahead.
#2 | |
Drives: '17 Toyota 86
I've got 18x9.5 +38 with 245/35R18 on Flex Z's. Sits pretty flush with a little bit of negative camber (I have -2.2 up front), no rub, and it didn't scrape.. well, before the springs settled at least. Raising it back up here soon. |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
You know there is a wheel and tire section of the forums for this kind of post, right?
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Drives: 2005 Toyota Camry
#5 | |
Car Dilettante
Drives: Nikki
Thank you!
Thanks for the share! That looks so clean, and yeah I have lowered it quite a bit and I realized it was a huge mistake trying to get out the driveway.
Car Dilettante
Drives: Nikki
I'm very new and haven't checked around the forum as much, but thank you!
#7 | |
Car Dilettante
Drives: Nikki
#8 | |
"Just installed coilovers" doesn't provide enough information on fitment and rubbing. You should also post up alignment specs, ride height, spring rate, and a bunch of other things. -alex |
#9 | |
Drives: SWP BRZ
what about mine? installed Flex Z as well and dropped about 1.2 all around and i am at -1.5 camber on all corners. thinking about to getting 18x9.5 at rear and 18x8.5 at front or 9.5 all around. not looking for meaty tire size so thinking about 245/40 ? |
#10 |
How do I shift?
Drives: '13 GBS BRZ
Name of wheels?
#11 | |
Zero toe if you want to primarily drive for street. More camber = more tramlining on grooved or crowned roads. be aware. It won't rub or otherwise be uncomfortable, but many people fail to see why too much negative camber is a bad thing on a street car. |
#12 |
Drives: 2014 GT86
mav1178: imho slight toe-in in rear may help on streets too. Car is more stable when accelerating, especially when low grip (winter/wet). It's not FWD self-straightening under acceleration, so may benefit of some alignment help.
| Tags |
| tires and wheels, tires help, wheel alignment, wheels and tires, wheels help |
| Installed Tein Flex A | _shnxfrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-31-2017 03:30 PM |
| Tein Street Flex suspension issue (lowering itself over time) | Sportsguy83 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 64 | 07-26-2015 05:00 PM |
| Can Anyone Translate Japanese?!?!(Tein Flex Recommended Specs) | Joe-G | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 02-28-2014 05:38 PM |
| Tein Type Flex - suspension setting question | koevasi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-03-2013 03:20 AM |
| Good tire to wheel specs? | _F-R-S_ | Tracking / Autocross / HPDE / Drifting | 4 | 01-18-2013 02:03 PM |
