Old 01-18-2013, 11:27 AM   #1
_F-R-S_
Drives: 13 whiteout scion frs
Good tire to wheel specs?
Looking for some help along the lines of tire sizes.. Im going to be doing track and autox and wi be going 17 x 9.
With an offset of 38. What of how wideshould i run either z2 or anyother high performance tire
_F-R-S_ is offline   Reply With Quote
Old 01-18-2013, 11:35 AM   #2
Iam not
Drives: 2013 FRS - red
You planning to compete in stock class or STX for autocross? You need to stay with 7" wide wheel in stock class. 9" wheels would put you into STX and it will be very painful handicap wise if you don't fully prep your car with coilovers, camber plates, etc in that class. Very expensive to do it right.
I would suggest going with 235/40 Direzzas or Hankooks on 7" wheels. The difference in handling over stock tires will amaze you.
KevinC
CS
Iam not is offline   Reply With Quote
Old 01-18-2013, 11:47 AM   #3
_F-R-S_
Iv had z1 on 7.5 and no not stx fk that
Old 01-18-2013, 12:32 PM   #4
It's hard to make a car that excels at everything.
If classing isn't important, try a 245/40/17.
_F-R-S_ (01-18-2013)
Old 01-18-2013, 02:03 PM   #5
xwd
I would second using 245/40/17.
The Following User Says Thank You to xwd For This Useful Post:
Wheel specs for Rocket Bunny Fenders deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 09-02-2022 10:14 AM
Wheel Directory: Niche NR6 18x8.0 +40 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-14-2013 11:51 AM
Recommend a good tire shop in LA/OC Hanakuso Southern California 10 12-08-2012 05:15 PM
wheel specs? VENOM~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-19-2012 06:41 AM
School Me: Good All-Around Tire - 18" random hero Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-24-2012 04:35 PM
