Drives: 2017 BRZ Limited
2017 BRZ iDatalink ADS-RR Headunit Install Compatibility
Hi guys,
I just wanted to know if anyone successfully installed the iDatalink ADS-RR Maestro along with the iDatalink HRN-RR-T01 harness with a Pioneer 4200 NEX. I bought these based on the recommendation of Crutchfied.com last week. At the time it showed that it was 100% compatible with the 2017 BRZ. I tried flashing the ADS-RR and now realize that is not the case as the 2017 BRZ is not even listed. I also went to the Crutchfield website and they now have nothing recommended for the 2017 BRZ. I bought the parts from different vendors, so am I SOL or is there a way to make it work somehow on a 2017 BRZ? Thank you for any information in advanced guys. |
Drives: FRS
try the 2016?
I personally haven't messed with the idata link before, I just have a 4100nex and a Bluetooth odb2 that I use with torque. what features are you trying to retain, or gain with the datalink? steering wheel controls, tire pressure readouts? i'm just curious mostly. IIRC the 4200 and 4100 are the same with the exception of the data link support, and I think the 4200 got a faster processor... which the 4100 needed if im being frank.
Drives: 2017 BRZ Yellow Spec Ed 1of500
I just had installed the iDatalink ADS-RR Maestro along with the iDatalink HRN-RR-T01 harness in my 2017 Yellow with a Kenwood DNX893S. The tech that installed it is a master Kenwood installer with the same unit in his Toyota. It was a major pain in the butt. Everything is working, Sirius, Backup camera, Garmin Nav, BUT only the "Source" steering wheel button works on the idatalink, waiting for them to release an updated flash. Sort of pissed that I have to pull the unit out to reflash it later on.
| The Following User Says Thank You to 007BRZ For This Useful Post: | Chimera (07-05-2017) |
#4 | |
YES. MY KENWOOD DNS893S is installed New idatalink flash is ready
See my other posts and pictures |
Drives: 2017 BRZ
Crutchfield is so far off with ANYTHING 2017+ on this platform. I had a chat trying to figure out what I needed and decided to go elsewhere, the guy insisted I needed a 1DIN unit...
I'm not doing the iDatalink though, need my OBD port.
Drives: 2017 86
I agree Crutchfield can sometimes be off. When I got my Kenwood HU for my 2017 86, the install instruction and ready harness was for 2013 FRS. Had to figure out how to wire the oem camera by myself. I did get the iDatalink for it, very happy with it. I did get a OBD2 splitter from Amazon so I can use the other OBD2 port
#8 | |
ಠ_ಠ
Drives: 860 SansOverspray
You don't have to use the OBD port, there are CAN bus leads on one of the stock radio harnesses.
Some more information can be found here. Last edited by mrderp; 03-14-2018 at 04:14 PM. |
| The Following User Says Thank You to mrderp For This Useful Post: | cjd (03-13-2018) |
| Official 2017 MY CHANGES (Full Document) and Backwards Compatibility Discussion | Stang70Fastback | BRZ First-Gen (2012+) — General Topics | 301 | 06-08-2018 02:07 AM |
| 2017 BRZ Headunit (and Dash!) Replacement | Dok Henz | Electronics | Audio | NAV | Infotainment | 105 | 04-14-2018 12:23 AM |
| Subwoofer Install for dummies (Stock Headunit) | Matty-T | DIY (Do-It-Yourself) Guides | 2 | 07-27-2015 03:14 AM |
| List (you contribute) Phone Bluetooth Compatibility BRZ stock headunit | robot | Electronics | Audio | NAV | Infotainment | 15 | 01-09-2014 01:44 PM |
| oem headunit install | encity5 | Electronics | Audio | NAV | Infotainment | 4 | 07-22-2012 10:27 PM |
