Old 07-17-2012, 08:51 AM   #1
encity5
encity5's Avatar
oem headunit install
Is installing an oem headunit as straightforward as taking old unit out and connecting the same plugs to the new one? No wiring harness or using seperate USB aux plug, or splicing wires?
Was thinking about installing bespoke or the older pioneer premium audio unit. And jut wanted to know if the plugs on them are the same a the stock unit and no fancy splicing require to get the mic or oem usbaux plugs to work. Or if this would just be safer to have my dealer install it if I buy from them
encity5 is offline   Reply With Quote
Old 07-17-2012, 09:09 PM   #2
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
did you buy the bespoke or something ? those are the only two avail that are oem
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports-
SoCAL
rikdrt1 is offline   Reply With Quote
Old 07-17-2012, 09:34 PM   #3
encity5
encity5's Avatar
I figure that the scion headunits that were available for the 2012 TC are also compatible with the frs since features are the same and I've seen some dealers sell the frs with the pioneer premium audio unit which is the model before the bespoke.
Different areas of the world also get different factory headunits
Old 07-17-2012, 10:58 PM   #4
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
yep, well thats what im trying to do - just dont like the analog looking unit and was thinking of buying the premium for 479 .. i dont care too much about the bespoke..
is that what u are thinking .
btw, i took the unit off and it is very easy and everything is plug-play... i would just do it yourself...
SoCAL
Old 07-22-2012, 10:27 PM   #5
encity5
encity5's Avatar
I heard the bespoke unit uses a different USB/aux cable than the stock head unit.
Anyone have Amy info on this?
aftermarket headunit and USB /AUX encity5 Electronics | Audio | NAV | Infotainment 0 07-16-2012 07:28 AM
Pairing phone on base headunit...help Phil_Dunphy Electronics | Audio | NAV | Infotainment 6 07-14-2012 12:51 PM
FR-S headunit replacement drei CANADA 7 07-11-2012 04:08 PM
Spoiler Install CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 1 07-07-2012 10:43 AM
Stock FRS Headunit/Speaker preformance jflogerzi Electronics | Audio | NAV | Infotainment 8 06-03-2012 01:03 AM
