Old 08-28-2013, 07:44 PM   #1
ein311
Drives: 2013 Scion FR-S in Firestorm
What is this plug & this connector for? (FR-S, stock HU)
So I did some forum searching trying to figure this out but didn't get anywhere... apologies if it has been answered already.
I was wiring up a sub to the stock HU and noticed a connector on the stock HU was unplugged. The HU came out pretty easy so I don't think I yanked any cables out of the back.
Upon searching for any loose cables/harnesses/etc., I noticed a connector pretty far back just sitting there. It's taped up pretty well so there's not enough slack for it to reach the HU and it doesn't look like the plug would fit anyway.
http://imgur.com/a/GA8Li
Can anyone clue me in as to what the plug and the connector are for?
ein311 is offline   Reply With Quote
Old 08-28-2013, 09:44 PM   #2
brianhj
Drives: 2017 Camaro 1SS
I'm guessing it's something that just isn't used in this car. Like a 6-disc changer or something. It's probably used in other Scion cars.
brianhj is offline   Reply With Quote
Old 08-28-2013, 09:57 PM   #3
Rumbaar
Victim's aren't we all
Rumbaar's Avatar
Drives: Toyota GTS 86 - Pegasus White
Can you take a picture showing the actual wires [colors] attached to that additional plug, that might help with determine what it's used for.
Looks like the speaker wire harness to me: I took some pictures of mine when I changed head units.
Rumbaar is offline   Reply With Quote
Old 08-28-2013, 10:07 PM   #4
ein311
All the plugs in your pictures are on my head unit.
I'll pull the HU out again and try to take a bit more detailed picture...
stay tuned
Edit: Here's the plug & the corresponding wire colors going to it.
Old 08-28-2013, 10:12 PM   #5
brianhj
Does everything work???
Old 08-28-2013, 10:22 PM   #6
ein311
I'm guessing maybe it's for Sirius/XM? I just realized I have the option for XM but my car doesn't have a built-in receiver.
Old 08-28-2013, 10:29 PM   #7
ein311
It sure does! I'm just one of those curious folk that want to know why something in my car isn't connected.
Sent from my One using Tapatalk 2
Old 08-28-2013, 10:36 PM   #8
brianhj
Yeah that's probably it. My Altima had an empty port that was for the other trims that had sat radio or cd changers.
Old 08-29-2013, 10:46 AM   #9
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
It's listed in the schematics as "option connector", D29. The pink and blue wires are CAN bus, orange is B+ (fused through the dome lamp fuse), black/yellow is ground, red/black is accessory power (radio fuse).
Don't know what the 'option' would be for, though.
Admiral Ballsy is offline   Reply With Quote
The Following 2 Users Say Thank You to Admiral Ballsy For This Useful Post:
ein311 (08-29-2013), RedReplicant (12-09-2022)
Old 08-29-2013, 11:52 AM   #10
kanundrum
Drives: 2013 Whiteout FR-S
Looks like a Subwoofer connector (looks the same on the scion tC)
Old 08-29-2013, 06:32 PM   #11
ein311
Alrighty. Thanks for the help! I'll just keep on ignoring them, then.
Old 08-29-2013, 07:02 PM   #12
Admiral Ballsy
Shorter of breath
No reason for an audio connector to have CAN bus data. Might be the same physical connector part, though.
If I was guessing, I'd say it's potentially for diagnostics...maybe like that multifunction pod that turbo Cobalts and HHRs had as an option? Can't think of much else that would require switched power and CAN data....and nothing else.
Old 08-11-2015, 10:42 PM   #13
philooo
Drives: 13' Scion FRS Track car
does anybody knows where to buy a male connector for the D29 connector ?
this connector offer some great cable with constant ant switched power, plus can high and can low.
philooo is offline   Reply With Quote
Old 08-11-2015, 11:13 PM   #14
stevesnj
stevesnj's Avatar
Did you look on the top of the HU? there should be a diagram sticker of what the plugs are
My 2016 Build thread
Gear Stick HELP FaNtaSy Engine, Exhaust, Transmission 12 03-18-2013 12:03 AM
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug sikest Electronics | Audio | NAV | Infotainment 7 01-21-2013 10:38 PM
RPM stick between 3.5 - 4.5 Realm Engine, Exhaust, Transmission 6 09-18-2012 02:10 PM
Car Name; Reason why FT-86 won't stick xantonin Scion FR-S / Toyota 86 GT86 General Forum 54 07-17-2011 01:52 PM
