Drives: scion frs
CEL problem, help
c1201 p0016 p0011 SCION FRS 2015y
The car is not under warranty. I bought it on copart and I repaired Car was and is run and drive. Where to find a problem to get started |
Drives: scion frs
The plug that comes in is cracked (blue) Could this be the cause of the error? |
Drives: UK GT86
P0011 - Camshaft Position "A" - Timing Over-Advanced or System Performance (Bank 1)
P0016 - Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A) Both are related to the same sensor/cam system. It could be a faulty sensor or it could be something else. The best thing to do would be to swap sensor with another and see if the codes change. C1201 appears to be a generic ECM fault code, will probably clear with the other 2.
.: Stealth 86 :.
| Problem with car around 4K rpm | Scion1738 | Issues | Warranty | Recalls / TSB | 13 | 11-27-2015 11:59 PM |
| TRC problem | Toyota GT 86 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 05-15-2014 07:42 PM |
| Big Problem | jpit | Engine, Exhaust, Transmission | 156 | 05-13-2014 08:21 PM |
| DDM HID Problem | LinknLog | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 04-11-2013 12:43 PM |
| A bit of a problem | Gost | Other Vehicles & General Automotive Discussions | 13 | 02-12-2013 07:07 PM |
