Old 04-12-2017, 04:47 AM   #1
dostoyevsky
Drives: 2017 BRZ
How bulletproof are our engines when N/A?
Hey guys, I got a question, how bulletproof are our engines when N/A?
How much power can these engines handle and last the life of the car?
dostoyevsky is offline   Reply With Quote
Old 04-12-2017, 05:00 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Depends on the round being used.
[ame="https://www.youtube.com/watch?v=0ZihidK9BA4"]Engine Block Penetration Test .22lr to .50bmg - YouTube[/ame]
Old 04-12-2017, 05:14 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
https://www.truedelta.com/Scion-FR-S...1096,2013-2016
This website tracks user-driven data to report things like reliability. You can join up and become part of the community and report on your car. It looks like the FR-S has been really good reliability-wise.
Old 04-12-2017, 08:05 AM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Not.
Old 04-12-2017, 10:54 AM   #5
fika84
fika84's Avatar
From the research that I've done, you just don't want to over rev the stock engine all that much without building the top end and replacing the rocker arms. Also want to work on potential oil pressure problems at high revs.
Do some research and figure out the weak points and you'll be in good shape.
fika84 is offline   Reply With Quote
Old 04-12-2017, 02:58 PM   #6
dostoyevsky
Drives: 2017 BRZ
How can the oil pressure problems be solved?
By over rev do you mean the stock 7.3k rpm is too much?
Old 04-12-2017, 03:07 PM   #7
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
We have not fired rounds of ammunition into our engine blocks to verify.
CounterSpace Garage is offline   Reply With Quote
Old 04-12-2017, 03:12 PM   #8
Shady195
Drives: '13 10 Series FRS #1203
You guys are slacking..
I'm gonna go over to FA20Club, I hear those guys really know what they're doing
Shady195 is offline   Reply With Quote
Old 04-12-2017, 03:13 PM   #9
strat61caster
strat61caster's Avatar
Stock redline is fine, bounce off the rev limiter all you want.
Oil temperature and pressure only becomes an issue during sustained high rpm driving, usually only occurs on track days or if you're driving around >6k rpm for awhile for whatever reason (backroad, wasting gas on the freeway, driving "spiritedly" etc.)
If you don't plan on tracking or running the engine over 5k rpm for 10+ minutes frequently you don't have to do anything about this 'problem'. Only a few have had serious problems and the majority are experienced track day people.
The easiest solution most go with is an aftermarket oil cooler. But depending on what you're doing it may not be necessary at all.
ineedyourdiddly
Old 04-12-2017, 03:14 PM   #10
Shady195
A stock motor, with proper maintenance...
Will last a long time even with tons of abuse.
Adding power, well the more power you add the less reliable it's going to be. I'm of the opinion that if you have to ask this question, you probably are not ready for the headaches that come with modifying a car and the potential catastrophe to follow.
Old 04-12-2017, 03:22 PM   #11
CounterSpace Garage
While California is a gun friendly state, it's not something we can splurge on right now. However, there are limitations to how much a factory block can take. For example, the engine lasts for a long time with proper care, a very good tune, if foreign objects don't penetrate the walls (internally or externally), and if you don't stay committed on the throttle for long periods of time.
Old 04-12-2017, 03:33 PM   #12
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
With too much power on a stock motor it will shoot rounds out of the block for you.
Old 04-12-2017, 03:38 PM   #13
Shady195
NEVER LIFT. NOT EVEN ONCE!
Old 04-12-2017, 04:05 PM   #14
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
With an alloy block even the rimfire would be a worry
Scrappydoo is offline   Reply With Quote
Headlight Modification like Bulletproof FRS. xFury Cosmetic Modification (Interior/Exterior/Lighting) 4 02-03-2016 09:59 AM
What is Currently Going On At Bulletproof Automotive BPAuto Off-Topic Lounge [WARNING: NO POLITICS] 6 12-18-2015 10:18 AM
Bulletproof frs yetiFR-S FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 05-19-2014 10:20 PM
Bulletproof Automotive's SWP 6MT BRZ Limited BPAuto BRZ First-Gen (2012+) — General Topics 22 08-18-2013 12:39 PM
ZELE x Bulletproof Automotive 86 BPAuto Cosmetic Modification (Interior/Exterior/Lighting) 44 06-26-2013 12:13 PM
