Old 03-28-2017, 04:19 PM   #1
sroby
Drives: 2015 Firestorm 08/05/15
Afr bung on overpipe
I will be doing my sprintex install soon and am going to run an afr gauge. I need to know if it matters to have the bung welded on the header after the secondary 02 sensor or can I have it welded on my overpipe. I have already had my header ceramic coated didn't want to have to redo it. I didn't know if that location close up toward the front of the over pipe and not on the header, would alter the afr numbers or not. Thx in advance. Steve
sroby is offline   Reply With Quote
Old 03-28-2017, 05:26 PM   #2
Amputechture
Drives: 2014 BRZ
Do you have a cat in your header? If not, then you'll be fine to place it there.
Amputechture is offline   Reply With Quote
Old 03-28-2017, 05:37 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You can, but be warned that you will have virtually no access to it.
Much better to have it on the front end of the front pipe.
-alex
Old 03-28-2017, 06:06 PM   #4
KnightRyderx2
Drives: 2014 FR-S
You could but that would be a tight fit. The best place for it is on the front pipe close to the over pipe.
KnightRyderx2 is offline   Reply With Quote
Old 03-28-2017, 07:00 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
-alex
I had the AFR bung in my overpipe and it was easily accessible and visible from right by the battery. I wish I had pictures.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Trust86 (03-28-2017)
Old 03-28-2017, 07:53 PM   #6
mav1178
mav1178's Avatar
I know which part of the car you're talking about, and yes you can easily access it... just a hell of a lot easier if it was under the car, esp if the bolt becomes difficult to take out.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Sportsguy83 (03-28-2017)
Old 03-28-2017, 10:56 PM   #7
sroby
Yea I am running the Gruppe-s uel no cat header. Invidia overpipe, Berk highflow cat front pipe and the q300 cat back. I have the overpipe and header Cericoated. I was just looking down like you had said and it looked like I had room on the overpipe. But if it would still give me an accurate reading there is plenty of room on the front pipe before the cat. So to be clear as long as I installed it in front of the high flow cat on the front pipe I will be ok? and again thanks for all of your help and support I get from the forum. Thx Steve
Old 03-28-2017, 11:00 PM   #8
sroby
Alex, thanks partner, I just re read everything and you answered my question. I will put the bung on the front pipe just down from the collector but before the cat. thx Steve
Old 03-28-2017, 11:22 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
Do you still have the secondary cat? You could mount the bung downstream of that and make an extension cord.
That's what I'm planning on doing.
Old 03-28-2017, 11:30 PM   #10
sroby
I do. I am running the Berk High flow catted front pipe. I get it now Ultra, for it to read the mixture for the af meter it has to be after the cat. in my case since the one is not in the header it has to be the secondary. I think I have that correct. Hell I am confusing myself now (Ha) It doesn't take much anymore. thx partner
The Following User Says Thank You to sroby For This Useful Post:
Ultramaroon (03-28-2017)
Old 03-28-2017, 11:45 PM   #11
Ultramaroon
not playing cards
You can retain the cat-efficiency measurement function that way. Legit in the spirit of the exercise. I'm planning on keeping my OEM front pipe.
Old 03-28-2017, 11:46 PM   #12
sroby
right on partner thx
02 bung in front pipe ort895 Engine, Exhaust, Transmission 5 03-28-2016 01:23 AM
A/F Wideband O2 Sensor Bung Location FyeaFRS Engine, Exhaust, Transmission 2 06-01-2015 10:17 AM
Fitting an additional O2 bung on Stock header? dave- Engine, Exhaust, Transmission 6 02-19-2015 10:54 PM
HELP: O2 bung on Rev Works header stripped? btoast Engine, Exhaust, Transmission 9 12-21-2014 07:11 AM
FS: AVO 2.5" Overpipe and Catless Front Pipe w/ o2 Bung DesertFrs Engine, Exhaust, Bolt-Ons 0 04-01-2014 01:37 AM
