Old 03-19-2017, 12:42 PM   #1
ajh88
Drives: 2013 Firestorm FR-S
Smartphone mount steady enough for track use
I'm looking at turning an old iPhone 6 into an oil/water temp gauge using the DashCommand OBDII app and wanted to know if anyone has suggestions on a mounting solution. Any thoughts? Would love to hear if anyone else uses a similar setup and how they like it.
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 03-27-2017, 09:05 PM   #2
justinco
justinco's Avatar
Drives: 2022 GR86
Get a ProClip dash mount, they are great. I have used one in autocross for the past year and a half with an 8" tablet. Solid as a rock.
justinco is offline   Reply With Quote
Old 03-28-2017, 04:58 PM   #3
Jonsey
Jonsey's Avatar
Ram mount.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 03-29-2017, 09:30 AM   #4
Icecreamtruk
Drives: Track preped NA FRS
I have a ram mount, have not had any trouble with it, that thing sucks! I mean, in a good way.
Old 03-29-2017, 09:56 AM   #5
DarkSunrise
DarkSunrise's Avatar
I've been using a cheap ebay suction mount and it's never failed me at the track. I just clean the windshield and suction cup with some water before mounting, and to be extra safe, I put double-sided tape behind my device.
I know someone who uses the RAM mount for his phone and says it works well too.
2022 BRZ Build
2013 FR-S Build
Old 03-29-2017, 09:57 AM   #6
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
A can tell you that a vent mount is not strong enough for HPDE. I bought a Ram mount recently, and have been experimenting with mounting on the front triangle section of the driver's side window. Got the phone mount that's a custom fit instead of the universal twist style. More secure: http://amzn.to/2nvfOMB
Still working on optimized routing for the power cable. Right now I have a 10 foot lightning cable running from the center console, under the seat and then tucked under the floor mat.
TofuJoe is offline   Reply With Quote
Old 03-29-2017, 10:33 AM   #7
PDM 2
Pokemon Master
PDM 2's Avatar
Drives: 2014 Scion FR-S
Scosche magic mount.
'10 MazdaSpeed 3 Velocity Red Mica - SOLD
PDM 2
'14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS
PDM 2 is offline   Reply With Quote
Old 03-29-2017, 12:13 PM   #8
strat61caster
strat61caster's Avatar
The ram mount suction cup is definitely strong enough, but the universal X-grip has a bit of slop in it, so no good if you're using the phone for accelerometer data, but likely good enough for most other uses.
ProClip looks good, and cheap, probably takes the cake if you want to run a tablet (autoxers running Solo Storm like Justin above), might have one soon.
ineedyourdiddly
Old 03-29-2017, 12:17 PM   #9
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
I got the X-Grip for a ram mount, all my video is very shaky, but it has never fallen off.
G-Man is offline   Reply With Quote
Old 03-29-2017, 12:27 PM   #10
strat61caster
I don't mean it will fall out, I mean that my phone can twist maybe +/-10 degrees the way the x-clamp is designed (at least the model I have), so if you are taking accelerometer data, the phone can twist and skew your data. That might be why you're getting shaky video as well, I've never used it to take video so I don't know.
The only time I've gotten shaky video off a suction cup mount (not ram) was when the suction cup was not properly secured.
ineedyourdiddly
Old 02-07-2018, 01:44 PM   #11
Biggins
Drives: Yes
Do you have a photo of your ProClip tablet set-up? I am going to try running some data this year, and I'd like to buy everything once. I have a 7" tablet and was going to get the mount for it, but I was worried it might not fit with where the ProClip dash mount is located in our car? Thanks.
Biggins is offline   Reply With Quote
Old 02-07-2018, 02:08 PM   #12
justinco
justinco's Avatar
Drives: 2022 GR86
It should fit. I have an 8" tablet and it's fine. It will cover up some of the controls on the right side but not a big deal. Sorry for the crappy pics, I only swap in the tablet mount when I am racing.
Old 02-07-2018, 02:40 PM   #13
Biggins
Drives: Yes
Perfect, thank you! I was worried that the tablet mount would hit the radio.
Old 02-07-2018, 03:24 PM   #14
Pat
Pat's Avatar
Drives: 2023 BRZ
I love my Scosche. It's good on the track as long as I'm not driving over gators. The vibration causes my phone to slip. Big individual bumps do not.
Matey's BReeZy. Slow and steady Matey Member's Car Journals 23 08-23-2015 05:43 PM
Is your steering wheel steady ? xtral BRZ First-Gen (2012+) — General Topics 6 08-16-2015 02:21 PM
Slow and Steady Simok Member's Car Journals 5 02-06-2015 04:26 PM
Proper maintenance for a steady diet of e85 Kronos Software Tuning 44 11-20-2014 01:43 PM
Car lurching at steady speed batmobilefrs Issues | Warranty | Recalls / TSB 10 04-04-2014 08:33 AM
