Drives: Raven FRS
Car lurching at steady speed
So when I'm driving at a constant speed the car will begin to lurch as if it wants to stall but doesn't. I just had the fuel pump replaced by the dealer to fix the chirping issues and the only mod I have in the engine is an AEM intake. They told me it was bad ECU software and they rehashed it with brand new updated software and that still didn't fix the problem. Wondering if anyone else has seen our heard of this. Car is back at the dealer right now and I'm just wondering what kind of b.s. they might try to throw at me and if any of you all have suggestions.
Drives: '13 Black Subaru BRZ Limited
I've heard some hear-say about some dealers not doing a very good job on fuel pump installs. Maybe a botched install and it's starving the car. Just a thought, I have no idea what I am talking about.
Is this before the engine warms up, you're in first gear and under 10 miles an hour?
Drives: 2013 Scion FR-S, Raven, Manual
I had the same issue at normal driving speeds and this was my own in tank fuel pump install error. Seeming as yours appears to be stock, not sure what it is. Slight lurching under 10mph in first gear is normal.
Drives: MDX, Camry
My best educated guess is not enough engine load combined with not being up to operating temperature. Happens to me every day of the week, rain or shine since I've owned the car.
There's a mismatch between the load on the car and the power the engine outputs, the engine goes 'oh shit' and compensates by adding gas to prevent a stall lurching forward and starting a vicious cycle of speeding up and slowing down because it's trying to maintain a set idle speed. An AT will smooth this out with the torque converter but a MT has a direct mechanical connection between the wheels and engine so you either got to give it some gas or pop in the clutch.
Of the few MT cars I've driven this has always been true, reducing the lurch would involve raising the idle speed to the car can apply more consistent power, sacrificing fuel economy and comfort levels (lower idle speed is quieter). When the car warms up it can provide a stronger more consistent idle so the problem is reduced. I may be missing something but that's my explanation. |
Drives: 2015 Series.Blue
Lurching at low speeds is also going to be drivetrain lash (mounts, sprung clutch disk, etc)
It's typical for a MT car unless you modulate the clutch a lot. |
Drives: BRZ Limited 6MT
OP - can you give some more detail? i agree with everyone on this post; if you're in 1st, under 10mph, and not being careful with throttle, you'll end up with wave-like lurching where the car speeds up and slows down rhythmically. usually can be easily corrected by hitting the clutch or giving it more gas.
that being said, i have noticed that the clunking from gas-on to gas-off in 5th and 6th gears is getting worse. used to be not noticeable at all, but now i can feel it in the chassis. |
#10 | |
Drives: Raven FRS
#11 | |
Does anyone get a lot of lash in 2nd as well? For example, clutch engaged, when you're off the gas then hammer it in 2nd? On my car, you can feel a split second of play/slop before it feels like you're getting rear-ended when everything catches up to the engine. I had someone rev the engine while I popped the hood, and there's minimal movement, so I don't think it's the engine mounts. My guess is there's a lot of movement in the rear differential. Perhaps it's time for rear differential bushings.
2022 BRZ Build 2013 FR-S Build |
| Seeing the top speed you went in the BRZ? | Corby26 | BRZ First-Gen (2012+) — General Topics | 42 | 12-08-2013 04:21 AM |
| Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
| What speed have you taken your 86 too | Ryan86 | AFRICA | 52 | 04-16-2013 02:45 PM |
| BRZ top speed | speedracer38 | BRZ First-Gen (2012+) — General Topics | 66 | 07-08-2012 03:37 PM |
| speed | eindio | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-27-2012 10:59 AM |
