Old 03-15-2017, 12:43 AM   #1
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Louder exhaust/turbo complications?
Soooo. I want my exhaust to be louder (currently running MXP SP) it's nice and subtle but I want a more aggressive sound to it. I am considering getting a muffler delete which I'll try and have a shop somewhere custom make into a straight pipe axle back but want to keep my quad tip (same size as tip). also considering an electronic dump pipe which I cannon find a production one to order. But I'm mainly concern about the turbocharger back pressure wise or if it may even ruin the turbo down the road.
Any helpful suggestions or recommendation or opinion is appreciated!!
turtlefeeder is offline   Reply With Quote
Old 03-15-2017, 12:49 AM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Tomei titanium exhaust all the way!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Trust86 (03-16-2017)
Old 03-15-2017, 04:35 AM   #3
turtlefeeder
Drives: UltraMFrS
I don't want to replace the whole exhaust just making is louder with exhausting part only muffler delete or dump pipe
Old 03-15-2017, 04:13 PM   #4
wparsons
wparsons's Avatar
Running a more open exhaust with a turbo is always a good thing. Freeing up the exhaust will help it spool faster.
That said, a turbo itself will quiet down the exhaust a fair amount over an N/A setup with the same exhaust. If you find the car too quiet N/A, it'll be way quieter with a turbo. I would just wait until the turbo is on the car to do the exhaust work so you're not doing it twice.
flickr
Old 03-15-2017, 04:17 PM   #5
turtlefeeder
Drives: UltraMFrS
Yeah the turbos been on the car just wonder if I'd run into issue with its current performance like would I need a retune. From what you said earlier, will the car sound still be louder if I muffler delete or it'll be the same as the setup I have with now with mxp sp?
Sent from my SM-N910T using Tapatalk
Old 03-16-2017, 03:12 PM   #6
wparsons
wparsons's Avatar
Sorry, misread your original post... I thought you were adding a turbo later.
A muffler delete will still be louder than your current setup, it just won't be as loud as an N/A car with the same exhaust.
You shouldn't need a re-tune, but with less backpressure you might notice the turbo spools quicker/sooner.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
turtlefeeder (03-17-2017)
Old 03-16-2017, 03:53 PM   #7
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
I'm running running the greddy t620z with an exhaust set up with the mxp quads and it's very neighborhood friend.
On the other hand, my buddy has the edlebrock sc + uel header + stock front pipe with the same mxp sp and it's pretty darn loud.
Might be better off getting an UEL header or if you want to keep the quad tip look, move to the Blitz because we have another local guy with it and it's a lot louder than the mxp.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
The Following User Says Thank You to Soloside For This Useful Post:
Old 03-17-2017, 12:52 AM   #8
turtlefeeder
Drives: UltraMFrS
Oh nice I'm currently running works stg2 turbo stock headers with both cat and mxp sp quad tips. It's subtle like really stock like sound level just louder on mid to high rpm but I'd like it louder
Old 03-20-2017, 08:55 AM   #9
Soloside
Then I'd suggest getting a set of UEL headers and if that's still too quiet, I'd upgrade the front pipe.
2014 Subaru BRZ
Old 03-20-2017, 08:07 PM   #10
turtlefeeder
Drives: UltraMFrS
Can't need to keep it carb compliant
Old 03-20-2017, 08:11 PM   #11
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I'd recommend an Axelback muffler delete. WORKS or Nameless both make great ones. I know you dont want to really change your setup but i know those both sound really good.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 03-20-2017, 08:13 PM   #12
turtlefeeder
Drives: UltraMFrS
Yeah that was one of the way I mentioned in the OP but idk if it would fit the mxp mid pipe
Old 03-20-2017, 08:24 PM   #13
Xxyion
Lowly Cartuber
Xxyion's Avatar
I cant imagine it wouldnt. I have the Nameless Axelback going to a WORKS midpipe. Unless the MXP has some crazy design (which i'm pretty sure its modeled after the Megan racing [or vice versa])
Old 03-21-2017, 12:58 AM   #14
turtlefeeder
Drives: UltraMFrS
How about the quad exhaust tip from mxp would it fit right onto the the works or nameless?
Help making TRD exhaust louder VinJah Engine, Exhaust, Transmission 10 08-09-2016 12:18 PM
Best way to make exhaust louder? Ryan_86 Engine, Exhaust, Transmission 15 08-08-2016 05:10 PM
Making TRD exhaust louder Quicksilverfrs Engine, Exhaust, Transmission 6 01-25-2016 01:49 PM
Exhaust too louder in the cabin Junkwipe Engine, Exhaust, Transmission 19 06-14-2014 01:16 PM
DIY louder exhaust and intake sw20kosh DIY (Do-It-Yourself) Guides 10 04-14-2013 10:27 AM
