Old 08-08-2016, 02:42 AM   #1
Ryan_86
Ryan_86's Avatar
Drives: 2016 Scion FRS - Steel
Best way to make exhaust louder?
got a 2016 frs with the factory installed borla axleback system. It sounds good but still kinda "stock and restrictive". Was wondering what upgrades would be best to make the car louder, little more rasp and crackle would be cool.
Cat delete over/front pipe? Unresonated midpipe? Both?
headers are a possibility but would have to save up. Thanks for any info yall have.
also wondering if any exhaust upgrades would be redundant and drowned out by the borla mufflers.
thanks
Ryan_86 is offline   Reply With Quote
Old 08-08-2016, 02:59 AM   #2
swarb
They all would work.
Catless header for power.
Front pipe because it's cheap.
Midpipe would be the last option.
I would choose header because you will actually be a little faster(5-10hp) instead of just sounding fast. Everything else would gain you 2-3hp if you are lucky.
Old 08-08-2016, 03:20 AM   #3
Sarang
Drives: 2010 LGT
Just put some washers in your exhaust flange before the cans a la Hogzaust
http://legacygt.com/forums/showthrea...ogy-35764.html
Sarang is offline   Reply With Quote
Old 08-08-2016, 04:14 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
That's your problem right there. Borla is not loud. Berk muffler dual tip delete is loud. Lose the muffler!
Old 08-08-2016, 11:35 AM   #5
Songha
Songha's Avatar
Drives: 2013 Scion FRS
Going full catless gets you loud. Video doesn't do as much justice.
2013 Scion FR-S | 6-MT | Raven Black | Performance Mods: Invidia N1 Catback, Invidia Catless Frontpipe, BC Racing Extreme Lows Coilovers, 1320 Performance UEL Catless Headers, 1320 Performance Overpipe, OpenFlash Tablet (Stage 2 UEL, 93 Oct. tune), Whiteline Front Swaybar, Whitelight Adj. Front Endlinks | Asthetic Mods: DS Style Front Lip, Rocket Bunny style flares, F1R F21s | MY BUILD THREAD!
Songha is offline   Reply With Quote
Old 08-08-2016, 11:44 AM   #6
jasonojordan
Drives: 2013 satin white brz limited
Changing to a muffler-less cat back as previously suggested will help. Keep in mind if you do that and then eventually do the rest of the exhaust your car will be very very loud. If you want to keep the stockish look with the borla id do headers and front pipe for the most change in tone power and volume.
jasonojordan is offline   Reply With Quote
Old 08-08-2016, 12:05 PM   #7
FX86
why do you want to annoy sleeping old ladies with a loud exhaust?
Old 08-08-2016, 12:41 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
run an open header
Old 08-08-2016, 01:09 PM   #9
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
jawn is offline   Reply With Quote
Old 08-08-2016, 02:47 PM   #10
Ryan_86
Ryan_86's Avatar
catless header and over/front pipe sounds the best. Good headers and a tune is around $1000-$1200. Was wondering if this catless front pipe that attaches to the stock header would make any difference?
http://www.ft86speedfactory.com/borl...g#.V6jThpMrIb0
Old 08-08-2016, 02:49 PM   #11
jasonojordan
Front pipe attaches to the over pipe not the header. It makes a tone difference but not louder. I just installed a ACE Cat-less front pipe on mine with stock header and over pipe and an N1 cat back with a none resonated mid pipe.
Old 08-08-2016, 02:53 PM   #12
FX86
pro tip: the real way to make an exhaust louder is keep the rpms up at 6000 all the time
Old 08-08-2016, 03:21 PM   #13
Brayden_23
Drives: Asphalt 2015 FRS
Step 1: remove overpipe
Step 2: start her up and let it rip!
Brayden_23 is offline   Reply With Quote
Old 08-08-2016, 04:15 PM   #14
Ryan_86
Ryan_86's Avatar
the link I posted is an overpipe/frontpipe combo that attaches to the header.
exhaust, header, loud, midpipe, pipe
How to make my car louder? Kolenda18 Engine, Exhaust, Transmission 30 03-29-2016 08:33 PM
Making TRD exhaust louder Quicksilverfrs Engine, Exhaust, Transmission 6 01-25-2016 01:49 PM
How to make my frs louder Shehadeh Scion FR-S / Toyota 86 GT86 General Forum 30 12-30-2014 09:41 PM
DIY louder exhaust and intake sw20kosh DIY (Do-It-Yourself) Guides 10 04-14-2013 10:27 AM
