Old 12-21-2013, 01:42 AM   #1
Junkwipe
Drives: Toyota Gt86
Exhaust too louder in the cabin
Hi guys, i have installed my new Agency Power catback yesterday.
When I went to try it out I noticed that the exhaust create a lot of disturbing sound in the cabin, when i accelerate or in a range of 3k/4k rmp i have a bass sound like when you have a side window down and you go fast.
How can i mitigate this annoying loud? I can try to disinstall the noise generator?
Junkwipe is offline   Reply With Quote
Old 12-21-2013, 01:46 AM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
That is called drone, different people have different tolerance to drone. The sound generator tube won't affect it and the only way to solve this is to either change your catback or add a res. Somewhere
Old 12-21-2013, 01:49 AM   #3
Junkwipe
Drives: Toyota Gt86
With a db killer it's not possible solve this a little?
Old 12-21-2013, 02:20 AM   #4
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
I suggest getting a perrin resonated catback or something with both a muffler and a resonator(invidia Q300 is another good choice). You can still have a loud car without all the droning. It may cost a bit more but you will love it!
IAmNotTheDriftKing is offline   Reply With Quote
Old 12-21-2013, 02:22 AM   #5
s2d4
s2d4's Avatar
Get rid of that junk.
Old 12-21-2013, 02:23 AM   #6
Junkwipe
Drives: Toyota Gt86
mmmh ok guys thanks a lot. I see in the new year what to do
Old 12-21-2013, 02:58 AM   #7
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
This is the best response so far. Anytime you swap the stock exhaust for a dual canister system, you are going to get a lot more vibration and resonance being transferred through to the cabin. The reason for this is that with a dual muffler design, you are essentially doubling the amount of noise being generated by your exhaust. Think about it, the exhaust gasses are being channeled to two identical mufflers, they are going to resonate against each other and make the low bass tones really amplified.
If you want a good sounding exhaust I agree, get then Perrin or Q300. I have a dual canister setup on my car because I love how it looks, but it definitely gets on my nerves when I'm just trying to run around town and drive normally.
That being said, I don't think I'll ever get rid of it because when you're on the twisties and you hit the gas the sound is absolutely amazing!
Originally Posted by humfrz
I'm old and lazy
Old 12-21-2013, 03:01 AM   #8
humfrz
Hi Junkwipe .....
Yep, it sounds like you have some drone from the exhaust.
Short of modifying the exhaust system, you may try stuffing a plug (the one that came out of the outlet behind the glovebox will fit) into the mouth of the sound generator (under the dash - behing the footwell carpeting on the passenger side).
Also, it may help if you line the spare tire well with a sound deadening material such as Dynamat (or, cheaper, Peel & Seal from a home improvement store). That sucker acts like a big drum.
humfrz
Old 12-21-2013, 06:20 AM   #9
Junkwipe
Drives: Toyota Gt86
Thanks to all guys.
Where i can find a resonator? I wanna try this way because the exhaust's sound it's awesome, it's a universal part or i have to contact agency power?
Old 12-21-2013, 01:13 PM   #10
350matt
Drives: toyota mr2/ Toyota GT86
Nameless sell a mid pipe with a resonator
350matt is offline   Reply With Quote
Old 12-21-2013, 01:19 PM   #11
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I installed a Q300 the other day. Great DD exhaust. Cruising is only slightly noticeably louder than stock.
SloS14 is offline   Reply With Quote
Old 12-21-2013, 01:34 PM   #12
krulux
Drives: 2013 Scion FRS
Take it to a muffler shop - have them install a 18" or if you want even less/no drone a full 24" resonator. Should only be $100-$150 installed. Ask them to weld, not clamp.
Buying a kit is is buying convenience... but a good muffler shop can build a comparable custom system for less. It's not rocket science - it's exhaust... and lot what folks praise as the best is nothing but opinion - IMO.
krulux is offline   Reply With Quote
Old 12-21-2013, 02:12 PM   #13
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Disinstall...lol
Old 12-21-2013, 02:45 PM   #14
Junkwipe
Drives: Toyota Gt86
I'm italian, in italy there aren't mufflers shop i have to do all from internet
Which is louder? Greddy sp elite or nameless 5inch BlackyRose Engine, Exhaust, Transmission 8 01-07-2014 07:51 AM
DIY louder exhaust and intake sw20kosh DIY (Do-It-Yourself) Guides 10 04-14-2013 10:27 AM
Cabin Dome/Map LED Anthonytpt Cosmetic Modification (Interior/Exterior/Lighting) 3 01-30-2013 07:31 PM
FRAM CA9482 Airfilter louder? Pake1 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 01-19-2013 07:55 PM
