Old 03-08-2017, 11:04 AM   #1
redlined600
redlined600's Avatar
Drives: Fr-s
Oil pressure location
I'm interested in adding a oil pressure warning light. My question is where I should pull the reading from.
1. Use an inline an adapter and pull right from the oil cooler line.
Or
2. Use the stock oil pressure location on the front.
I've looked at the galley plug on the top of the engine and am not comfortable bending the maf wires to gain the required clearance.
I'm not sure about the ramifications of removing the OEM sensor from the system.
Any thoughts?
Old 03-08-2017, 11:39 AM   #2
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Well the OEM sensor is just that, a warning light. I've heard you can remove it and no codes from the ECU.
But if you're going to remove it, might as well go with a full gauge that shows pressure all the time.
Cockatoo is offline   Reply With Quote
Old 03-08-2017, 11:59 AM   #3
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
This. If it's the same as my '13 STI - you can remove the OEM dummy warning light sender and put in a real oil pressure sender. I had it working wonderfully with a Defi gauge and no warning lights/codes (on the STI).
Yanbags is offline   Reply With Quote
The Following User Says Thank You to Yanbags For This Useful Post:
redlined600 (03-08-2017)
Old 03-08-2017, 12:41 PM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
This is 100% correct and the correct way to monitor pressure.
The idiot light basically means 'it's too late, dawg'.
Unplug the sensor, remove sensor, purchase galley plug adapter, add a proper gauge, done!
OEM Galley Plug adapter: https://www.rallysportdirect.com/par...il-galley-plug
Oil pressure gauges: https://www.rallysportdirect.com/scp...D=Oil+Pressure
Support a local vendor, but that's a good way to look at what's out there.
Avoid prosport, consider AEM, Defi, and STRi.
JM.02
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
funwheeldrive (03-08-2017)
Old 03-08-2017, 12:53 PM   #5
Tokay444
Look for an Innovative dual temp/pressure gauge.
The Following User Says Thank You to Tokay444 For This Useful Post:
TofuJoe (03-08-2017)
Old 03-08-2017, 01:30 PM   #6
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
There's an oil gallery plug just under and to the left of the air condition pump. This is the best spot to take an oil press reading.
Lunatic is offline   Reply With Quote
Old 03-08-2017, 02:59 PM   #7
redlined600
Drives: Fr-s
I guess I'd rather have a light than a gauge I'll end up ignoring. I don't want to have to check it, I just want to be alerted if I lose pressure.
If I end going with a gauge this one is very high on my list.
Old 03-08-2017, 03:47 PM   #8
stevesnj
stevesnj's Avatar
By then it may be too late...
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
JazzleSAURUS (03-08-2017)
Old 03-08-2017, 05:06 PM   #9
redlined600
Drives: Fr-s
Maybe I don’t have a strong enough understanding of the oiling system but why would a drop in pressure show up on a gauge but not a warning light. That’s a bit of a rhetorical question as I understand the principal difference between a light and a gauge. I’m just not convinced that a gauge is going to alert me any faster. If I’m wrong, I’m wrong…..
For example; if an oil cooler line ruptured, would the system sustain enough pressure to not trip the light? How much (if any) is dependent on where the sensor is located, such as the oil cooler return line vs oil galley. Hence my original question.
Old 03-08-2017, 05:50 PM   #10
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I think the issue is that the light illuminates when you have, essentially, no pressure. I dunno what the exact level is, but the threshold to where it turns on is really low. That's like your TPMS sensor letting you know that you have 0 PSI in your tire, at which point you're already fucked. A gauge allows you to identify a DROP in pressure, but not one so severe that it causes engine problems. To use the TPMS analogy, that's like letting you know that your tire pressure has dropped to 25 PSI, which isn't catastrophic, but gives you a heads up that you might want to look into it before your tire essplodes.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 03-08-2017, 08:13 PM   #11
Lunatic
Lunatic's Avatar
Most aftermarket oil pressure sending units are 25 psi. With our cars idling as low as 5 psi a light will be on quite a bit of the time.
Old 03-08-2017, 09:26 PM   #12
redlined600
Drives: Fr-s
Right, that's a fair drawback, ignoring(or second guessing) the light at low rpm.
Old 03-08-2017, 10:31 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
Pressure gauge or none, I've for years considered replacing the idiot light with a loud buzzer.
Old 03-08-2017, 10:43 PM   #14
Lunatic
Lunatic's Avatar
That would be a way to go. In my Minibusa track car I used a round LED tail light for a low oil pressure warning light. About 2" diameter. No way were you going to miss that baby.
The Following User Says Thank You to Lunatic For This Useful Post:
Ultramaroon (03-08-2017)
Amp Location? FNCrazy Electronics | Audio | NAV | Infotainment 10 07-09-2016 09:54 AM
BOV location? teddydoggy Forced Induction 2 09-17-2015 08:09 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
ECU box location?? RehabJeff86 Electronics | Audio | NAV | Infotainment 2 09-18-2013 02:34 PM
