Old 12-22-2014, 04:18 AM   #1
Hempo
Drives: Subaru BRZ
High rev
So guys, how many out there have raised their revlimit and to what RPM? If you've raised it have you done any headwork/new valves etc?
I'm having my heads fixed and also going 1mm up on both intake and exhaust.. thinking maybe raise the revlimit to 8500rpm if it shows any gains
Hempo is offline   Reply With Quote
Old 12-22-2014, 04:46 AM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
It will, the stock heads were a choke point at anything after redline on this motor. With headwork its a lot more free flowing, I'm fairly sure @Element Tuning's revs to 9k with headwork and still makes power iirc.
Old 12-22-2014, 05:39 AM   #3
Hempo
Drives: Subaru BRZ
Sounds interesting I'm running the Innovate SC, should be nice with high revving SC-whine
Old 12-22-2014, 12:46 PM   #4
Mild2Wild
Drives: Firestorm FR-S
I'm pretty sure you will easily over-rev the SC by raising the redline. Certainly will with one of the smaller pullies available...
Mild2Wild is offline   Reply With Quote
Old 12-22-2014, 01:51 PM   #5
fika84
fika84's Avatar
Not much to open up on the intake side, but you can get significantly more flow on the exhaust side. @Element Tuning did the oversize valves and head work. They also did quite a bit of research and development on oil flow that is really worth a read! I VERY much want a 9k redline turbo motor.
http://www.ft86club.com/forums/showthread.php?t=63723
http://www.revvolution.com/blog/2014...he-fa20-4u-gse
fika84 is offline   Reply With Quote
Old 12-22-2014, 01:59 PM   #6
sw20kosh
Drives: 2013 Black FR-S
That unit is too small.
Old 12-22-2014, 03:13 PM   #7
mid_life_crisis
Drives: FR-S 10 #103 AT
To get power at 8500, won't he need cams too?
Old 12-23-2014, 04:43 AM   #8
Hempo
Drives: Subaru BRZ
Trying to calculate the max rpm but can't get any kind of consistency in the different SC-calculators out there..
I know i will/be very close to overrev the SC with a raised redline along with the 70mm pully. I might try fitting the 80mm pully along with a raised redline just to see the difference for fun
Old 12-23-2014, 06:26 AM   #9
Malt
Drives: 2015 WRX
I could be wrong but I swore I saw something along the lines that the 70mm pulley is very slightly over revved at 7500rpm. Raising the rpm limiter to 8500 certainly would over rev it. On the topic of raising RPM limits, I've always wondered if its better to change the final drive after increasing the RPM limit to offset the reduction in available speed in each gear. People swear up and down that a final drive mod is one of the best things they ever did and a higher RPM limit would make that even better.
Malt is offline   Reply With Quote
Old 12-23-2014, 07:41 AM   #10
Hempo
Drives: Subaru BRZ
Just spoke to my tuner, going to test the 80mm aswell and se what kind of gains it'll make with a higher redline vs the 70mm with a lower redline
Old 12-23-2014, 08:18 AM   #11
fika84
fika84's Avatar
If you read the article I posted (the revvolution one) in here you will quickly learn that our cams are pretty good from the factory with relatively large lobes and good duration (I'm sure there is room for improvement but not many people are making cams for this motor yet) and if you see one of these motors with the intake manifold off you will say, "wow this thing is screaming... BOOST ME!!"
EDIT - The article doesn't say we have good duration, but it does say that with such little valve to piston clearance we will need to be careful with changing the lobe size and duration.
Plus people are making power at the high revs with slight port work which leads me to believe that it's not necessary.
Old 12-23-2014, 12:05 PM   #12
350matt
Drives: toyota mr2/ Toyota GT86
the bigger thing is making the valve train robust enough to withstand the high rev loads
its not just a case of whacking up the spring load, have a read of the 9krpm oiling and bearings thread , element tuning has found that the followers are a weak point and can fall apart
but I do agree these things would be great with a 9K rev limit
350matt is offline   Reply With Quote
Old 12-23-2014, 01:00 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
^^this^^ They've done it and know what it takes.
Old 12-23-2014, 06:01 PM   #14
350matt
what have they done exactly? from what they've posted it seems the axles in the followers are less than consistent in position, so some are good and some are bad
so plough through a bunch of stock parts to find a set with good axle positions and then add some reinforcement ?
this does mean that there are engines out there with weaker than designed folllowers, so travel carefully people
Low Torque @ High RPM VS High Torque @ Low RPM Mikeez Other Vehicles & General Automotive Discussions 41 02-20-2014 01:18 PM
How high can i get my rpm in a new car? 10series#1969 Scion FR-S / Toyota 86 GT86 General Forum 11 02-14-2014 01:52 AM
Is this a high price!? Jonoraven93 Southeast 3 07-18-2013 01:28 PM
DRL or high beam or both? jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 5 06-09-2013 03:09 PM
