Old 02-10-2017, 01:50 PM   #1
Uplink
Uplink's Avatar
Drives: anything you let me
Max throttle opening...
Hey guys, figured this might be an appropriate place to post this question. I've recently installed a P3 Gauge on my 100% factory tune FR-s and noticed my throttle position never reads higher than 90%, all the way to redline in any gear with foot buried in the carpet.
I know from working with throttle cable / TPS cars it's really about sensor voltage and on my Vette proper TPS WOT resistance actually reads as 96.4% open when scanning. So I understand there could be some variation but does 90% sound low? With drive by wire, would that be holding back top end power? It would definitely explain why the car struggles to make 120mph even on a track as big as Poconos.
Thanks in advance!
Uplink is offline   Reply With Quote
Old 02-10-2017, 02:47 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
http://www.ft86club.com/forums/showthread.php?t=92974
http://www.ft86club.com/forums/showthread.php?t=48289
http://www.ft86club.com/forums/showthread.php?t=34629
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-10-2017, 08:01 PM   #3
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
FWIW my OFT will show me 10% throttle after the first 1/4" or so of actual physical pedal depression. It's basically the reverse of what you're experiencing but is very common afaik.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 02-10-2017, 11:07 PM   #4
Uplink
Uplink's Avatar
It's one of the reasons I hate drive by wire systems. At least with a mechanical linkage there can be no doubt how far open the blade actually is.
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
EcuTek: Is there a way to limit throttle opening ? trueno86power Software Tuning 7 10-31-2015 07:34 PM
Need Help Opening Taillights in PDX XanRules Northwest 7 10-07-2015 05:07 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 12:44 PM
