[||•]=(86)=[•||]
Drives: 2017 Toyota 86
EcuTek: Is there a way to limit throttle opening ?
Hi guys!
I've recently buy the K&N Typhoon intake system for the FR-S. ECU is still learning for the MAF scalling but I'm impress how close from stock it is (.5 to 4.5 LTFT correction now). Work great for nerly all driving situation except one: Low rpm WOT in 1st gear (Below 2000RPM). The problem is air turbulance from the MAF being to close from the throttle body. But I really want to keep this intake. I've used Shiv fuel map to soften the bug, but it still there. http://www.ft86club.com/forums/showthread.php?t=87182 If I apply like 20% of throttle input in this zone, the problem is not present and car run fine. So there is my question: Is there a way to limit throttle opening in a RPM specific section with EcuTek? Thanks for your help !
#2 | |
Drives: UK GT86
With ECUtek and custom maps you could easily limit accelerator pedal per RPM/Speed/Gear etc.
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 10-30-2015 at 12:57 PM. |
[||•]=(86)=[•||]
Could you give me a tip (again) how to do this?
Drives: UK GT86
Do you have access to Custom Maps? If so there is a really simple way to do it.
However I'll go through a possible way to do it on any platform: Open the Accelerator Pedal to Desired Torque table (SI Drive Map on ECUtek). The X Axis is the pedal and Y Axis is the RPM. In the RPM range you're on about copy the values in the 21% column into all the higher % cells. That means that the following calculations will ask for no more torque than when you push 21% currently. You'll have to smooth the values in between 2000 and 2400 RPM but you might need to have a play to make it work. Just remember the relationship between the desired torque and the Wide Open Torque Threshold tables.
.: Stealth 86 :.
Drives: '23 BRZ Limited
Why are you going full throttle in first gear below 2000 rpms?
Or just don't floor it if you want to limit the throttle opening? Everyone has built-in traction control, it's your right foot. |
#6 | |
[||•]=(86)=[•||]
I do have access to custom map, I only don't have the full raceroms features (4 swichable map, speed density tuning etc...) But theirs 2 throttle body table. One is called " Accelerator Pedal to Desired Torque #1" and the other one " Accelerator Pedal to Desired Torque - SI drive mode S". The SI drive mode: Is it releated to the "Sport" mode ? I'm maybe wrong, I'm just asking in case. @OkieSnuffBox, in some "f*ck, I've engaged in the road but the other guy goes way more more faster than what I taught" situation you don't have time to think "I must not slap the throttle WOT". It's only a precaution :P
#7 | |
Drives: UK GT86
#1 may be cruise control or even not used. I'm fairly certain that SI Drive is the normal pedal to desired tq table. Pedal maping doesn't change in sport mode.
.: Stealth 86 :.
#8 | |
[||•]=(86)=[•||]
I'll try this and I'll give you some update
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 12:20 PM |
| Ecutek map with speed limit? | Fizz | Software Tuning | 5 | 01-28-2015 11:32 AM |
| AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? | tracerit | Engine, Exhaust, Transmission | 11 | 02-15-2014 12:44 PM |
| Rev Limit | Acid18 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 01-13-2013 04:55 PM |
