Old 01-26-2017, 01:29 AM   #1
MyGT86Yas
Drives: 2017 WRB BRZ
Exhaust spring bolts
I recently put on a aftermarket exhaust and now one of the exhaust spring bolt is gone. Pretty sure the exhaust was installed properly and the sale at the part department told me the spring bolt on our car tend to fail. Is it not recommended to use normal bolt and nut to replace the spring bolt since the mid section of the exhaust is designed the flex? Thanks.
MyGT86Yas is offline   Reply With Quote
Old 01-26-2017, 01:58 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Try it and if it doesn't leak it should be fine. I have ran it with regular bolts on this car and my previous one with no noticable ill effects. Granted im no engineer and can only guess at the true use of spring bolts (to keep pressure on the donut gasket or due to flange design??) so I could be dead wrong but I dont think your car will blow up either wau
Old 01-26-2017, 05:47 PM   #3
MyGT86Yas
Yeah will replace it with regular bolt and nut and see. In my understanding the exhaust shouldnt flex or expand that much I think.
Sent from my Nexus 6P using Tapatalk
WTB: OEM exhaust spring bolts 1Cor10:23 Canada Classifieds 0 05-16-2016 11:55 AM
Eibach Sportline Lowering Spring front and rear camber bolts WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-20-2014 10:09 AM
Why doesn't it come like this from the Factory? (Front Camber Bolts + Spring Swaping) Kostamojen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-05-2013 01:20 AM
RCE Yellow spring kit, should I get the camber bolts? jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-20-2013 07:36 AM
Exhaust MP/FP (flange/spring bolts) install help! rbizzle004 Engine, Exhaust, Transmission 9 03-04-2013 11:34 AM
