Old 01-23-2017, 02:13 PM   #1
Tysoncrosby21
Drives: 2017 Asphalt 86
Resonator Install
Exhaust shops locally want 120-150 to install a resonator into my cat back. I'm wondering, should I bite the bullet and have it done. Or cut it myself, use ultra copper and some sleeve clamps?
Tysoncrosby21 is offline   Reply With Quote
Old 01-23-2017, 03:06 PM   #2
Sarang
Drives: 2010 LGT
Do you already have the resonator in hand, or are they supplying it? Because I paid $45 to have a reputable nearby shop weld in a vibrant resonator on my 3" stainless system on my car.
So if that's just for the weld I would get some quotes.
Sarang is offline   Reply With Quote
Old 01-23-2017, 03:39 PM   #3
Tysoncrosby21
I have the resonator in hand, called 6 different shops. All quoted me between 120-150 just for the cut/weld.
Old 01-23-2017, 04:04 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Damn, that is pricey. Looks like you don't have much of a choice though.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-23-2017, 04:10 PM   #5
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
You could remove your exhaust system, mark the area where you want to have it cut and welded, then take it to a local welding shop, they should be cheaper than most chop shops.
Old 01-23-2017, 05:09 PM   #6
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I had a resonator installed into the piping of my catback for $50. Which resonator did you buy, and is it a tight fit to get it in there? Do they have to move flanges or something? I can't understand why it would be so expensive otherwise.
ajcarson11 is offline   Reply With Quote
Old 01-23-2017, 05:49 PM   #7
Tysoncrosby21
No moving flanges, just a straight cut and weld. It's a vibrant ultra quiet.
Old 01-23-2017, 07:09 PM   #8
Sarang
Drives: 2010 LGT
You could see if there is a mechanic or welding school nearby. That price doesn't make any sense to me.
Even posting up a craigslist add looking for someone to weld it ought to be cheaper.
Old 01-23-2017, 08:11 PM   #9
Tysoncrosby21
Well, found a shop FINALLY that quoted me 60 bucks. Hoping the estimated high and it'll be less. There is zero clearance or fit issues for the resonator.
Installing Resonator? l0aded Engine, Exhaust, Transmission 36 07-14-2022 11:06 PM
Intake resonator?? DIE1000DEATHS Engine, Exhaust, Transmission 16 12-03-2014 09:17 PM
COLD AIR INTAKE INSTALL AND SOUND TUBE / RESONATOR REMOVAL FRSpappa Engine, Exhaust, Transmission 16 06-21-2014 01:13 AM
Removing The Resonator Nicolas0esp1 Engine, Exhaust, Transmission 12 01-22-2014 03:52 PM
Exhaust Resonator Brndn704 Engine, Exhaust, Transmission 3 08-20-2013 03:31 PM
