Old 01-19-2017, 03:42 PM   #1
Kenjoe
Drives: 2016 Brz
Wheel fitment help
Hello everyone!
I have a 2016 BRZ and I'm wanting to change my wheels to a 17x8.5 or 9 with a 30 offset and a 1in drop. My question is if I do that will I run into any clearance issues? Secondly, what would be a good tire size? Any information will help, thank you!
Kenjoe is offline   Reply With Quote
Old 01-19-2017, 03:58 PM   #2
j0307
j0307's Avatar
Drives: 2015 Subaru BRZ Series.Blue
Originally Posted by Kenjoe View Post
Hello everyone!
You won't have any clearance issues at all, tire size if you want a meaty setup, 235/40 17
j0307 is offline   Reply With Quote
Old 01-19-2017, 03:58 PM   #3
http://www.ft86club.com/forums/showthread.php?t=7535
http://www.frsproject.com/tire_size.php
why? (01-20-2017)
Old 01-19-2017, 03:59 PM   #4
j0307
j0307's Avatar
Originally Posted by j0307 View Post
You won't have any clearance issues at all, tire size if you want a meaty setup, 245/40 17
Old 01-19-2017, 04:02 PM   #5
Just noticed the link is down for the calculator.
Here: http://www.ft86club.com/forums/showthread.php?t=25177
Old 01-19-2017, 04:08 PM   #6
Impureclient
Drives: 2015 FR-S
I'm surprised your helping with "fitment" here, Tcoat.
Impureclient is offline   Reply With Quote
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
gramicci101 (01-19-2017), Tcoat (01-19-2017)
Old 01-19-2017, 04:25 PM   #7
I gave up. Apparently "fitment" is now the appropriate noun, pronoun, verb, adjective, adverb, conjunction, preposition, and interjection for anything involving the actual word "fit".
The fitments of anger it was causing were affecting my health and I just want to fitment in with the crowd.
goldenfri (01-19-2017), Impureclient (01-19-2017), why? (01-20-2017), winstonscifi (01-19-2017)
Old 01-19-2017, 04:30 PM   #8
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
this link works. http://frsproject.com/
i run 17x9 +25 with 245/40 tires and it fits with a 1.4-1.5" drop all around. however i am running coilovers and -2.5 camber all around.
your set up may hit the strut tower in the front depending what tire size you pick. with coilovers however you can go for a meatier set up without any worry.
DuMa is offline   Reply With Quote
Old 01-19-2017, 04:47 PM   #9
Kenjoe
Drives: 2016 Brz
Thanks for the information everyone! Helps alot.
The Following User Says Thank You to Kenjoe For This Useful Post:
Tcoat (01-19-2017)
Old 01-19-2017, 06:04 PM   #10
ryoma
ryoma's Avatar
I have a 17x8 +45 wheel with 235/45 tires and lowering springs with -1.2 camber up front. the inner sidewall of the front tire is about half an inch from the spring perch. you might run into rubbing issues if you go with a wider wheel on stock suspension. if you're getting coilovers then it will be no problem.
Old 01-19-2017, 06:21 PM   #11
j0307
j0307's Avatar
I'm gonna be running an 18x9.5 +38 with a 245/40 18 on lowering springs, idk what my camber is at but the lowering springs are one of the highest drops, it's about -1.5. There is about 2mm of clearance between the strut and the tire though.
Wheel fitment help FrsBoyz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-20-2016 12:37 PM
Help with wheel fitment jplake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-31-2016 08:08 AM
Wheel fitment help. sskillzz12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-28-2015 12:49 PM
Wheel fitment odessitik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-30-2014 08:39 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 06:33 PM
