Drives: 16 Silver BRZ, 04 Silver WRX wagon
Cheapest way to get better bass
First off I am no audio aficionado. My stock system with under seat subwoofer in my 2004 WRX is still fine for my purposes after all these years. However, when I listen to the same songs in my BRZ, you realize how there is no bass in the car. I have not found an under-seat woofer that would work, the subaru stock one for the trunk is about 6-700 installed and my local guy wants about 700 for his woofer in the trunk.
Any ideas on a cheaper way? As I said not looking for the best, just need some bass. Also I listen to rock and alternative. Thanks |
Off Topic
Kicker CompRT81, Kicker PXA200.1, Pioneer UDSW200D box, Metra 70-1761 and 71-1761 wiring harnesses, and some 8ga power and ground wire from any car audio shop.
Instructions: http://www.ft86club.com/forums/showthread.php?t=107369 |
Drives: 2017 BRZ - Dark Grey Metallic
I don't specifically know about the sub, but I can tell you the speakers AND tweeters are absolute garbage.
The stock woofers are super light and crappy feeling. If you look at the rears, there will be big globs of glue spilled onto the cone. The WRX by comparison, has a decent sound out of the stock system (with or without a sub). I've had the OEM Audio Plus put in both my BRZs. Makes it sound so good. The woofers themselves are about 3 x the weight of the stock ones. If you're lucky you might be able to pick up the kit for $1084.28 USD ($1500 AUD), but might be higher than you want to spend. |
Only happy when it rains.
Drives: series.blue
Honestly the first thing is a better head unit. That usually makes everything sound better. You should check out DIYMA.com, there are tons of different inexpensive audio options, and some of them are actually worth it.
Drives: 2016 STI DGM
![]() I hear she's all about it... 99¢ on Google Play Music.
Subaru STI :![]() |
Drives: RAVEN FRS
#7 | |
[insert cool phrase here]
Drives: BRZ Premium
You can YouTube how to wire the amp the car. That's what I did. Took me an hour or so.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: 86
Pick up an old/used/cheap 10" non powered bazooka tube. Stuff an Alpine Type X 10" in, hook to the amp of your choice, and enjoy! Even with stock everything else, this setup works quite well for Rock, Country, R&B, Hip-Hop, and a bit of classical as well.
Drives: 2013 Firestorm FR-S AT
Get the one with the included installation kit.
http://www.ft86club.com/forums/showt...hlight=bazooka Price has gone up. Cheapest I could find is on Amazon, OOS at Jet. Also look on eBay for a used one. https://www.amazon.com/Bazooka-BTA85...003E4K7HU?th=1 |
#10 | |
Drives: 14 BRZ
Used 8" Bazooka Sub from Craigslist: $60 Dynamat from Amazon.com: $60 1. Head unit first; as stated above. This gets rid of about 95% of the door speaker rattles. Just by doing this, many people would think you had replaced your speakers. 2. Disable your rear speakers and route wires from the head unit directly to a Bazooka subwoofer. Change the rear speaker setting on your head unit to "subwoofer". 3. Apply dynamat in areas that were most prone to rattle: rear license plate, front door speakers, and rear deck. Notes: -You will not miss those rear speakers as they don't have much output; they're similar like surround speakers in a home theater. -For whatever reason, the head unit powered the Bazooka better than the Bazooka's internal amp did. You can try either or to see which is better. -And for track days, the wiring on my Bazooka is quick release. I did this with a couple of buddies and some beer. Easily one of my favorite mods of 2016. |
#11 | |
Drives: 2015 BRZ Limited MT
#12 | |
Off Topic
#13 | |
thanks so much for your help. I'm completely new to audio setups |
#14 |
Off Topic
The harness came with it. That amp is actually made for motorcycles. Physically small amps like that will always have a harness instead of embedded RCA connections because it takes less space. The other amp I was looking at for my doors and surrounds, an Alpine KTP-445U, had the same setup.
| Do we have bass?? | Evo2Brz | Electronics | Audio | NAV | Infotainment | 34 | 04-02-2014 06:29 PM |
| Drum & Bass anyone? | Kodename47 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 10-11-2013 02:54 PM |
| Equus Bass 770 | zaptorque | Other Vehicles & General Automotive Discussions | 16 | 09-26-2013 02:39 AM |
| Bass question | nbafandan | Electronics | Audio | NAV | Infotainment | 9 | 02-08-2013 02:26 PM |
| Lack of Bass | elbachatero1 | Electronics | Audio | NAV | Infotainment | 13 | 07-31-2012 09:34 AM |
