Old 12-20-2016, 11:20 PM   #1
aminninja
aminninja's Avatar
Drives: gt86
atf oil change
can any one show me where is the drain plug and where is the overflow on the auto transmission oil pan. kinda confused here
aminninja is offline   Reply With Quote
Old 12-21-2016, 01:18 AM   #2
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Go here: FT86Club 2013 Subaru BRZ Factory Service / Shop Manual
Download the PDF manual titled 2012 BRZ Service Manual (PDF) Overview (I suggest downloading all the PDF's, they're pretty fun to look through)
Open the PDF, and search for:
14.Automatic Transmission Fluid or scroll down to page PM-68
Get dirty, have fun, and dispose of used fluids responsibly!
aegisdrgn is offline   Reply With Quote
Old 12-23-2016, 06:08 PM   #3
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
I think you actually need a special pump tool for auto trans, its not just drain and fill like the 6 MT
Old 12-24-2016, 09:13 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
You don't. it is drain and fill multiple times basically but you need to put it in the correct mode so the shift indicators tell you the AT is at the correct temp to measure correctly.
The SST they mention to jump the 2 ports can be replaced with a paper clip fyi. Just follow the service manual and you should be fine. It's not that bad now that I have seen it done. Just do it before driving anywhere or it'll take forever to cool down enough.
Wes (12-24-2016)
Old 12-26-2016, 08:32 PM   #5
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
What I have done with my other Subaru WRX is a drain and fill, once a year or once every 10K miles. Rather than try to get every bit out by doing it three times at once, it adds better fluid every year or so. Worked for 116K so far with no issues. I may do the same with the BRZ, depends how much effort I want to make. I drive the WRX pretty spirited and the fluid coming out always looks great. I am sure its overkill, but can't be bothered to do it three times in a row. I wish there was a better way.
Ernest72 is offline   Reply With Quote
ATF Change on 13 FR-S ft_86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-28-2016 11:26 AM
Name Change KingBaeless Off-Topic Lounge [WARNING: NO POLITICS] 26 05-11-2016 10:31 AM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 08:27 PM
Oil Change Craig Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 10-16-2013 10:04 AM
First Oil Change Jehuty77 CANADA 14 08-10-2012 12:54 AM
