Old 12-13-2016, 09:38 PM   #1
Lantana frs
Drives: 13 frs red
question for you guys
My butt dyno is sensing some unexplainable differences in performance as of late mostly low to midrange responsiveness. Sometimes it feels snappy and sometimes it feels like its turning 2 ac units. I've yet to log it but my oft is showing no iam fluctuation. Air temperature isn't varying enough to cause it imo. My car is a my13 with a new motor and ecu installed in early 14. To me, it feels like cam timing. My mods are Crawford power blocks and oft 93 tune. Thx in advance for your input.
Lantana frs is offline   Reply With Quote
Old 12-13-2016, 09:46 PM   #2
ryoma
ryoma's Avatar
is your tune optimized for the power blocks?
Old 12-13-2016, 09:57 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
You're just sensing day-to-day differences in air density, relative humidity, etc...
All engines behave the same way. Give yourself a high five for noticing.
Old 12-13-2016, 09:59 PM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You might like to put a relevant title to your post instead of "question for you guys".
Old 12-13-2016, 10:03 PM   #5
Lantana frs
Drives: 13 frs red
The tune is ots and I didn't take the time to synopsize into one sentence. Lol
Old 12-13-2016, 10:11 PM   #6
Lantana frs
Drives: 13 frs red
When I have the time I will tweak the tune. I have my heart set on a header and may remove the cpbs then.
Old 12-13-2016, 10:17 PM   #7
Lantana frs
Drives: 13 frs red
Jeez, I hope you're right. No cel, idles fine. You probably are right.
Old 12-13-2016, 10:25 PM   #8
Ultramaroon
not playing cards
Performance is also seriously affected by the nannies. If you're in the middle of a turn, even with the long press the computer won't let you punch it.
Driving in heavy rain is the worst because it severely interferes with driver input if it senses even the slightest bit of slip.
I'm a die-hard nanny hater but I'm also an old fart who's been comfortable with pushing the envelope for a looong time.
Old 12-13-2016, 10:54 PM   #9
Hawk77FT
Drives: GTS 86
Initially I thought is for
Hawk77FT is offline   Reply With Quote
Old 12-13-2016, 10:57 PM   #10
steve99
Have a look at you wot afr it should be no richer than 11.8
Have a look at your LTFT, the most common problem for NA guys is an intake or exhaust leak both will usually cause abnormally high LTFT like over 10%.
especially check your craford block install for leaks or dislodged hoses
Old 12-13-2016, 11:09 PM   #11
humfrz
..................................I'm a die-hard nanny hater but I'm also an old fart who's been comfortable with pushing the envelope for a looong time.
Ultramaroon, back-in-the-day ..........
humfrz
Quik question guys what do you do when you see a frs or brz Frsultramarine15 Scion FR-S / Toyota 86 GT86 General Forum 89 01-17-2015 03:34 AM
Dumb question for you guys. tedddee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-26-2013 12:51 PM
question for guys with headers Xdragonxb0i Engine, Exhaust, Transmission 22 04-22-2013 12:49 PM
Question for you guys!? mbh1101 Electronics | Audio | NAV | Infotainment 5 03-22-2013 03:48 PM
Question for the Phoenix area guys Pscylo Southwest 11 09-11-2012 12:28 PM
