Drives: 03 imprz rs, 13 brz
Dumb question for you guys.
Can someone explain to me why lowering the car requires a lower offset to stay flush? What else is changing that causes this? Angle of the wheel? Why is that changing with say 1" lowering springs?
I'm pretty clueless to the inner workings of suspension. Code:
WHEEL |-- STOCK HEIGHT --| |-- LOWERED 1" --| WIDTH FRONT REAR FRONT REAR 7.0 +25 +18 +23 +13 7.5 +31 +24 +29 +19 8.0 +38 +31 +36 +26 |
Drives: frs
i wouldn't think the offset would need to be different to be just as flush if the car is lowered or not. If anything it might just be compensating for the change in camber on the rears? The negative camber gained from lowering the rears will make it looks more sunk.
Driving Enthusiast
Drives: 2013 BRZ Limited
camber can change when you lover the car.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.My BRZ |
AutoX-10/10ths every run
I believe that under compression the front suspension gains positive camber. Lowering the car is the same as compressing the suspension relative to the stock height. I think that when the camber goes positive the top of the wheel/tire moves outward. A lower offset will move the tire/wheel in and away from the fender.
Not correct.
Drives: GBS Limited 6MT
Im not sure where that chart is from but they could be calculating the offset required to keep the scrub radius the same as stock.
[ame="http://en.wikipedia.org/wiki/Scrub_radius"]Scrub radius - Wikipedia, the free encyclopedia[/ame] |
| Question for you guys!? | mbh1101 | Electronics | Audio | NAV | Infotainment | 5 | 03-22-2013 03:48 PM |
| Hey dumb question? | FullTuneZN6 | Engine, Exhaust, Transmission | 4 | 03-06-2013 09:59 PM |
| Might be a dumb question about work orders | oops86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 02-13-2013 05:46 PM |
| Dumb question | ExWhyZer0 | Electronics | Audio | NAV | Infotainment | 2 | 01-25-2013 06:44 PM |
| No such thing as a dumb question? | DaveFTW | Issues | Warranty | Recalls / TSB | 4 | 08-08-2012 07:59 PM |
