Old 03-22-2013, 11:05 AM   #1
mbh1101
Drives: Raven 6mt FR-S
Question for you guys!?
Installed a 300w amp and sub this past weekend. Before I put all the panels back on I tried it out listening through the radio. Worked great!! Well when I put everything back together, everything works but my fm stations won't get any reception and my Sirius wont get signal. My HU is a pioneer avh-x5500bhs. I checked to see if maybe anything got unplugged on the back of the HU and everything was good. I have the 8 gauge battery power wire running on the drivers side through the factory gromet. Could this wire be interfering with the frequency ? And if so what can I do ? Thanks!!
mbh1101 is offline   Reply With Quote
Old 03-22-2013, 12:44 PM   #2
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Doubt it is the power wire but for a quick test you can disconnect it from the battery.
sure74 is offline   Reply With Quote
Old 03-22-2013, 12:55 PM   #3
wrohdejr
Drives: 2013 subaru limited wrb brz
Your antenna wire is unplugged or loose. Check the back of the head unit and make sure it's plugged in.
wrohdejr is offline   Reply With Quote
Old 03-22-2013, 12:58 PM   #4
mbh1101
I did its not unplugged and its connected properly to the wire harness.
Old 03-22-2013, 02:49 PM   #5
midnightfrolic
Drives: Scion FRS A/T raven
make sure the antennae cable is making contact with the port on the HU. did you connect the amp remote wire to the brown wire with the diamond symbol? where did you ground your amp? i grounded mine to one of the bolt securing a factory amp to the frame. located in the trunk.
midnightfrolic is offline   Reply With Quote
Old 03-22-2013, 03:48 PM   #6
mbh1101
Ya I did the same location for the ground. And I pulled the HU out and moved the antenna adapter around and it started working again. Almost as if there is a short. I'm not concerned so much about that its my Sirius.
Question for the guys with the cusco spin knob "drift" knob Juurian Cosmetic Modification (Interior/Exterior/Lighting) 5 03-13-2013 08:51 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
Question for the Phoenix area guys Pscylo Southwest 11 09-11-2012 12:28 PM
BRZ: What would you guys do? 01s0uljah CANADA 29 08-02-2012 09:29 PM
just to let you guys know . . . YoshiMike13 Off-Topic Lounge [WARNING: NO POLITICS] 24 07-06-2012 05:50 PM
