Old 12-12-2016, 01:53 PM   #1
drz400dude
How to run amp power wire
I'm moving my system from my truck to my frs. Just wondering what the best way would be to rub the power wire from the battery to trunk would be. I didn't see any way place to poke it through the firewall?
drz400dude is offline   Reply With Quote
Old 12-12-2016, 01:58 PM   #2
Impureclient
Drives: 2015 FR-S
To the left of the battery is a large rubber grommet on the firewall. The power wire will slide in easy right besides that wire loom.
Impureclient is offline   Reply With Quote
Old 12-12-2016, 02:01 PM   #3
drz400dude
I saw that, but where does it come in? It was dark when I looked so I couldn't see hardly. Is it just behind the firewall mat?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old 12-12-2016, 02:03 PM   #4
Impureclient
Drives: 2015 FR-S
If you look under the glovebox, you'll see where it comes in.
The Following User Says Thank You to Impureclient For This Useful Post:
soundman98 (08-11-2022)
Old 12-12-2016, 02:26 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I took out the sound tube generator thingy. Added a grommet in the hole for the sound generator, and stuck my 2awg power wire through it. I ran it on the same side as the battery to get the shortest run. (better for DC power)
Old 12-12-2016, 07:11 PM   #6
drz400dude
Thanks! That worked.
Old 02-07-2017, 03:05 PM   #7
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
are you guys just running it under the carpet? what all did you pull up and where did you run your power wire down the car?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 02-07-2017, 03:07 PM   #8
gramicci101
Off Topic
My power wire was small, so I took up the door sill and ran it under that, then fished it under the carpet and back seat into the trunk.
Old 02-07-2017, 04:07 PM   #9
Eman
Drives: 2013 Scion FR-S 10 series
OEM Audio plus has some good videos going over their installation. Even if you aren't installing one of their systems it's a good resource for wire routing.
Eman
Eman is offline   Reply With Quote
Old 08-10-2022, 09:30 PM   #10
Here2rock
Drives: 86 GTS
I am trying to the wire for an Amp, rather than going through the firewall just wondering whether I can use the black little holes as highlighted in the picture below.
https://www.mediafire.com/view/7fpgr...63342.jpg/file
https://www.mediafire.com/view/x94x4...63252.jpg/file
https://www.mediafire.com/view/h3t8w...63243.jpg/file
Here2rock is offline   Reply With Quote
Old 08-11-2022, 07:36 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
it just depends on what's on the other side of them
Here2rock (08-11-2022)
Old 08-11-2022, 09:09 PM   #12
Here2rock
Drives: 86 GTS
I might have to remove the carpet and some trimmings on the weekend to see where it leads to inside. I was hoping that someone may already have an answer.
Old 08-11-2022, 09:16 PM   #13
soundman98
soundman98's Avatar
i just used the wiring harness grommet underneath the battery
Here2rock (08-12-2022)
Old 08-12-2022, 06:06 AM   #14
Here2rock
Drives: 86 GTS
That is also an option, not the cleanest but a standard option.
Solved: Running 4-gauge power wire to trunk B-R-Z Electronics | Audio | NAV | Infotainment 3 11-08-2017 04:47 PM
Power wire for low beams on 10 series? timmydatooth Cosmetic Modification (Interior/Exterior/Lighting) 22 08-04-2015 10:29 PM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 02:04 PM
Re-wire Power outlets 2_slo DIY (Do-It-Yourself) Guides 11 10-04-2014 09:05 AM
Where to find ignition wire? One that gets power at key position 2 HRTROB Electronics | Audio | NAV | Infotainment 1 04-13-2014 12:44 AM
