Old 04-08-2014, 07:55 AM   #1
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Where to find ignition wire? One that gets power at key position 2
Yes I've searched, but I couldn't find anything. Where can I find a wire that gets power on key position 2? It's the position just before starting the car, with the warning lights turning on.
I need to find this wire to use for my gauges. They're currently hooked up to the switched 12v wire from the radio. They work fine but my oil pressure gauge starts beeping when I put the key in ACC (Low pressure warning). I also use the ACC position to charge my phone at the track. I don't want the gauges and sensors draining juice from the battery as well.
I've read some guys tapping into the 12v outlet in the glovebox, but mine gets power in position 1 (ACC).
Mine also has the push start button so I doubt I can find the ignition harness under the steering column.
Any ideas?
HRTROB is offline   Reply With Quote
Old 04-13-2014, 12:44 AM   #2
HapaHaole
Drives: Grocery cart
Here are your fuse choices,
10A ECU IG2, 7.5A Gauge, 15A AT , 1.5A IG2, 15A A/B main Those are the only fuses that are on the #2 aka IG2 circuit.
All these circuits are powered by the IG2 relay btw.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Cant find passenger window wire from drivers side remote.. help? luv85 Electronics | Audio | NAV | Infotainment 2 11-03-2020 09:13 AM
Okada / Ignition Projects / Cusco / Megan / aFe Intake & Filter / Agency Power Intake eauto Engine, Exhaust, Bolt-Ons 299 10-15-2014 01:44 PM
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
Recommend 12v Power - Ignition On Doc Scion FR-S / Toyota 86 GT86 General Forum 2 11-24-2012 02:34 AM
Stereo ignition switch wire bebopblues Electronics | Audio | NAV | Infotainment 0 11-04-2012 08:58 PM
