Old 08-01-2015, 01:38 PM   #1
timmydatooth
Drives: Scion Frs
Power wire for low beams on 10 series?
Im installing the led drl fog lights on my car and i have to tap a blue wire into the power wire of the low beams of my headlights so that the leds dim with the headlights on. As you know the 10 series come stock with hids so im having trouble locating where and which is the power wire. Do hids even have a power wire? I know on regular lights theres a red power wire and a black ground wire but i cant seem to find that with the hid lights. I uploaded a pic to show you what im looking at.
timmydatooth is offline   Reply With Quote
Old 08-03-2015, 09:32 AM   #2
timmydatooth
Drives: Scion Frs
Is it that gray plug with all the wires sticking out of it? Or is that for the drls?
Old 08-03-2015, 08:57 PM   #3
mush
mush's Avatar
that grey plug powers the whole headlight (bixenon/led)
Old 08-03-2015, 10:45 PM   #4
timmydatooth
Drives: Scion Frs
Ok cool so my best guess is ths power wire for the low beams is that big red wire with the little brown circle around it?
Old 08-03-2015, 11:25 PM   #5
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
That is correct. It is referred to as the #5 wire in this DIY about enabling the headlight LED DRL.
While you're all up in that wiring, might as well install the LED enabler - then you can tap the mod's wire, instead of the factory wire!
http://www.ft86club.com/forums/showp...61&postcount=1
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
timmydatooth (08-03-2015)
Old 08-03-2015, 11:37 PM   #6
timmydatooth
Drives: Scion Frs
thanks so much I've been trying to find an answer all week. lol
i think ill leave the led enabler mod alone since I'm gonna have the led fog lights on with the low beams anyway.
Old 08-03-2015, 11:39 PM   #7
aegisdrgn
aegisdrgn's Avatar
But it'll look so BADASS. I'll just leave this here...
Old 08-03-2015, 11:41 PM   #8
timmydatooth
Drives: Scion Frs
ok im convinced. where do i buy the harness wire for the led enabler mod?
Old 08-03-2015, 11:46 PM   #9
aegisdrgn
aegisdrgn's Avatar
You could make it out of parts listed in the aforementioned thread, or you could contact Diode Dynamics to see when they would stock this:
http://www.diodedynamics.com/store/c.../category/622/
I got mine pre-made by a member on this forum, before he stopped making them. It required de-pinning the harness and wrapping two wires (only frustrating part was stuffing the wrapped wires back into the harness plug).
Good luck!
Old 08-04-2015, 12:05 AM   #10
timmydatooth
Drives: Scion Frs
Good luck!
for the diode dynamics plug n play module I'm assuming the red wire is still the power wire for the low beams? the wire placement is different from the stock module.
Old 08-04-2015, 12:11 AM   #11
aegisdrgn
aegisdrgn's Avatar
It is kinda hard to tell - looking at picture "3" I believe the brown wire leading to the top right plug is the #5 wire we want. Once you plug it in, it should be simple to figure out which one is the #5.
Old 08-04-2015, 12:30 AM   #12
timmydatooth
Drives: Scion Frs
how do i test to see which wire is the power wire? do they just unplug from the module?
Old 08-04-2015, 12:41 AM   #13
aegisdrgn
aegisdrgn's Avatar
Yes, you can definitely de-pin the Diode Dynamics plug (specifically, the side that plugs into the back of the headlight). Pretend you want to plug the module into your face, you should be able to take a pick/thin flathead screwdriver and depress the plastic "tongue" that holds each pin in place - then simultaneously push the pin out.
I'm pretty sure whatever wire they connect to the #5 position will have low-beam power, but it'll probably be a good idea to check with Diode Dynamics.
Old 08-04-2015, 03:08 AM   #14
mush
mush's Avatar
i had better luck with the beat sonic module than with the diode dynamics
sure its $20 more, but that $20 WILL save u headaches
trust me ive had first hand experience with both
i also had a user made module, the beat sonic is a much "cleaner" look
http://www.beatsonicusa.com/other-ac...es/dlm2ep.html
The Following User Says Thank You to mush For This Useful Post:
NyC Zn6 (08-04-2015)
Solved: Running 4-gauge power wire to trunk B-R-Z Electronics | Audio | NAV | Infotainment 3 11-08-2017 04:47 PM
10 Series headlights flash high beams MemphisR Cosmetic Modification (Interior/Exterior/Lighting) 10 05-08-2015 09:19 PM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 02:04 PM
Re-wire Power outlets 2_slo DIY (Do-It-Yourself) Guides 11 10-04-2014 09:05 AM
Where to find ignition wire? One that gets power at key position 2 HRTROB Electronics | Audio | NAV | Infotainment 1 04-13-2014 12:44 AM
